Post Reply  Post Thread
Chaos Warrior Style Capes Tutorial
Author MessageChaos Warrior Style Capes Tutorial
Hammerhand
Bull Centaur
Posts: 487 - Aug 2007
Group: Dawi Zharr
Market Rep: 1
Slaves: 14
Post: #1
Chaos Warrior Style Capes TutorialHammerhand 09-12-2007
***Warning*** this is not a stand alone tutorial.  You will need to have seen Xanders BFSP conversion tutorial to use it. Follow the link:
http://www.chaos-dwarfs.com/forum/showth...hp?tid=204
This tutorial is alsopart ofmy army blog (that I posted in the wrong place)  if you want to see my other stuff, follow the link:
http://www.chaos-dwarfs.com/forum/showth...p?tid=1045
Preparation.
To start with, I completely carve up the dwarf as Xander does in his tutorial, only I completley remove the head and shield, and carve down into the shoulders with my craft knife/needle file to get the helmet to sit in the right place.  Then I glue in the plastic add-ons such as helmet, shield and arm.  The arm requires a long pin armature wrapped in a little greenstuff, you don't need to worry about the detail in this arm as most of it will be covered by the cape.  I then add the scale mail as in xanders tutorial, and add on a greenstuff shield arm. Again, this will mostly be covered by the cape.  Be sure to remove any pouches/equipment from the Dwarf's back.  Your start point should look like this.
Fur Collar
First off, I sculpt on the fur collar.  Make a GS sausage about the size shown in the picture below and place it carefully around the neck area:
Next, using a flat sculpting tool, smooth down the GS and spread over the area of the model you want to cover:
Once you are happy with the coverage (it doesn't have to be 100% smooth as you will be texturing it anyway) Take a sharp sculpting tool and begin engraving small grooves starting from the neck area and working down to the bottom of the collar like this:
Games workshop's website has a tutorial for this technique, just follow the link if you want more detail
http://uk.games-workshop.com/convershunk...-stuff/14/
Cloth Cape
It's a good idea to let the collar cure before you start the main cape.  Make a GS sausage about the size shown in the picture and carefully place it along the bottom edge of the dwarf's armour:
Next, use a flat sculpting tool to spread the GS over the area you want to cover with the cape.  This will probably be the whole of the back area:
As the warriors arm is raised, there will be a bit of cape flaring away from the body.  Use a flat sculpting tool and your thumb to pinch the edge of the GS and pull it gently away from the body as shown in the picture blow:
Once you have done this gently smooth out any finger prints using a flat sculpting tool **this can be fiddly but persevere, it's worth the effort at this stage**.  Your finished flat cape should now look like this:
Modelling the Folds
***You need to let the cape cure fully before starting to model the folds***
As these are core troops, I am only putting 3 basic folds in the cloth.  You can put more in if you wish, simply alter the amount of GS to alter the depth of the folds.  For now, we will just cover basic folds.
Make 3 GS sausages about the size shown in the picture below.  Place one carefully where you wish the centre fold to be:
Once you are happy with it's position, place the other 2 sausages either side where you think the folds would look best:
Once you are happy with their position, use a flat sculpting tool to work the sausages into the cape, creating a triangular 'tent' shape.  I find it works better to have the outer folds leaning towards the centre and the centre fold shaped evenly as shown in the pictures below:
And that's it, your finished basic Chaos Warrior style cape.  Go on then, you can see him from the front too!
Notice where the cape sticks out slightly under the arm.  The beard is done exactly as in xanders tutorial.  I have tried both scultping the beard before and after the cape, I think it's slightly better to do it after but it doesn't make much difference TBH.
2017 Image Salvage
It's been a long time baby, but I guess the mark of Hashut just burns too deep.......
This post was last modified: 08-10-2017 01:15 PM by Admiral.
09-12-2007 06:12 AM
Gilzam
Chaos Dwarf Daemonsmith
Posts: 110 - Sep 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #2
RE: Chaos Warrior Style Capes TutorialGilzam 09-12-2007
Cheers for this man I was having troubles with greening capes and this helps so much.
Now I have an urge to convert yet another hero, damn you! Shock
The races of the world are doomed.
Just as soon as I decide which headgear to wear.
09-12-2007 05:49 PM
wizzbang
Unregistered
Post: #3
RE: Chaos Warrior Style Capes Tutorialwizzbang 09-15-2007
Hammerhand Wrote:
Chaos Dwarfs with tails, run for your lives! Tongue
This guide might also be handy for converting a standard Dwarf cloak of the 7th ed. boxed set to a more grim version.
09-15-2007 05:15 PM
Quote this message in a reply
AGPO
BOAR CENTAUR!
Posts: 3,130 - Mar 2007
Group: Retired Staff
Market Rep: 0
Slaves: 1271
Post: #4
RE: Chaos Warrior Style Capes TutorialAGPO 09-23-2007
As I said in the other post, just remember if you cock this up you can simply sculpt fur over the top.
Check out my blogs!:
Chaos Dwarfs (6/6/09)Other shiny things (13/11/11)
I follow the Grumpy But Responsible Gamers' Charter. Join us!
Sojourn Wrote:
FYI Wilmark, the only alcohol I'm drinking is from that bucket
09-23-2007 09:16 AM
wallacer
Hashut's cow pimp
Posts: 3,538 - Feb 2007
Market Rep: 4
Slaves: 1046
Artisan's Contest - Bronze Image Gallery Contributor - Bronze Word of Hashut - Contributor Wiki - Major Contributor Blackshard Army Medal - 10000 PTS
Post: #5
RE: Chaos Warrior Style Capes Tutorialwallacer 09-23-2007
Very simple and effective.  Congratulations.
Army pics: http://www.chaos-dwarfs.com/forum/showth...888&page=1
09-23-2007 04:42 PM
Xander
Chaos Dwarf Ambassador
Posts: 4,757 - Feb 2007
Group: Hashut's Admin
Market Rep: 7
Slaves: 504
Post: #6
RE: Chaos Warrior Style Capes TutorialXander 10-07-2008
Whoa, I missed this tutorial! Excellently done! I love it!
Join us on the new forum. Come help us test it out!
https://discourse.chaos-dwarfs.com
10-07-2008 02:25 PM
Kera foehunter
Zharr Nauggund Alpha Female
Posts: 8,568 - Sep 2007
Group: Dawi Zharr
Market Rep: 14
Slaves: 153
Post: #7
RE: Chaos Warrior Style Capes TutorialKera foehunter 10-07-2008
hammer hand !! this is great for everone !! There are a lot of new people that this will help them out greatly !!! thanks for sharing
10-07-2008 05:48 PM
bobkian
Hobgoblin
Posts: 23 - Oct 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #8
RE: Chaos Warrior Style Capes Tutorialbobkian 10-08-2008
that's really good I might try that.
10-08-2008 04:09 AM
Arcuballis
Slave
Posts: 6 - Sep 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #9
RE: Chaos Warrior Style Capes TutorialArcuballis 10-08-2008
Very nice tutorial!!!! I've tried countless of times to make capes but the drapes were too hard to do... I always tried to actually fold the GS'ed cape, but your method seems much more intelligent!!!!
Thanks for that!
*Arcuballis hides back in the shadows to make countless capes for their models*
Cheers!
Arcuballis
10-08-2008 11:00 AM
Obsidian
Voice of Hashut
Posts: 1,185 - Jun 2007
Group: Immortals
Market Rep: 11
Slaves: 226
Silver Army Medal - 2000 PTS Golden Hat - Silver x2
Post: #10
RE: Chaos Warrior Style Capes TutorialObsidian 10-08-2008
Really great tutorial! Cheers!:
Just a quick question though, why don't you sculpt the cloak first and then the fur?
The Obsidian Forge
10-08-2008 11:20 AM
Merchant
Bull Centaur Hero
Posts: 522 - Sep 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 5
Post: #11
RE: Chaos Warrior Style Capes TutorialMerchant 10-09-2008
I have been having problems making fur, so thanks to you for the help making a tutorial on how to. Happy
Now my Lammasu might have a chance to be done Happy
Blasting Zombies since 1987!
When the traitor's hand strikes, it strikes with the strength of a legion.
10-09-2008 02:59 AM
grunts
Chaos Dwarf Hero
Posts: 281 - Sep 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #12
RE: Chaos Warrior Style Capes Tutorialgrunts 10-09-2008
hey hammerhand, thanks for the tutorial.  I just tried it out on one of my sorcerers and it looks good.  the only think i did different was to do the cloak first and the fur afterwards.
Sarcasm...beats killing people
10-09-2008 04:09 PM
Borador Away
Collector of Renegades
Posts: 1,796 - Dec 2008
Group: Immortals
Market Rep: 5
Slaves: 1
Post: #13
RE: Chaos Warrior Style Capes TutorialBorador 12-14-2008
great tutorial ^^ keep up the good work
12-14-2008 11:24 AM
theimmortal
Hobgoblin
Posts: 45 - Dec 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #14
RE: Chaos Warrior Style Capes Tutorialtheimmortal 01-12-2009
thanks allot mr hhTakes Hat off
now i have a slave, i can pratice my axe swing
01-12-2009 05:52 PM
Possibly Related Threads...
  Dwarf Miner to Chaos Dwarf Warrior Tutorial Hashut's Blessing 4 5,889 01-14-2010 09:00 PM
Last Post: Hashut's Blessing
  Xander's BFSP Chaos Dwarf Warrior Conversions Xander 31 45,508 11-19-2009 01:38 PM
Last Post: nitroglysarine
View a Printable Version
Send this Thread to a Friend
Forum Jump:
