K'daai destroyer conversion stonehorn/thundertusk
| Author |
MessageK'daai destroyer conversion stonehorn/thundertusk |
Hashutcopper
Hobgoblin
Posts: 26 - Mar 2012
Group: Dawi Zharr
Market Rep: 0
Slaves: 3
| 04-03-2012 05:06 AM |
vulcanologist
The Mongrel General
Posts: 1,143 - May 2010
Group: Immortals
Market Rep: 1
Slaves: 230
04-03-2012 06:03 AM |
Hashutcopper
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 3
RE: K'daai destroyer conversion stonehorn/thundertuskHashutcopper 04-03-2012
Definitly going for lava in the cracking and pouring out of the mouth.
Their walls will fall
Their faith will fail
Their flesh will tear
| 04-03-2012 06:07 AM |
Smog
Chaos Dwarf Warrior
Posts: 66 - Apr 2011
Group: Dawi Zharr
Market Rep: 0
Slaves: 26
RE: K'daai destroyer conversion stonehorn/thundertuskSmog 04-03-2012
The Thundertusk kit really is a great starting point for a Destroyer!
04-03-2012 06:31 AM |
Zanko
Prime Frurndar of Hashut
Posts: 2,352 - Dec 2008
Group: Immortals
Market Rep: 10
Slaves: 683
04-03-2012 02:24 PM |
Hashutcopper
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 3
| 04-03-2012 05:25 PM |
Kronosv13
Chaos Dwarf Warrior
Posts: 56 - Apr 2012
Group: Dawi Zharr
Market Rep: 1
Slaves: 17
RE: K'daai destroyer conversion stonehorn/thundertuskKronosv13 04-12-2012
It's shaping up really well, i really dig the cracking skin and the lava flow from the mouth.
04-12-2012 08:20 PM |
Hashutcopper
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 3
| 04-18-2012 05:34 AM |
deadlydeceiver
Chaos Dwarf Daemonsmith
Posts: 161 - May 2007
Group: Dawi Zharr
Market Rep: 2
Slaves: 33
04-18-2012 05:43 PM |
brotsorrow
Chaos Dwarf Hero
Posts: 290 - Apr 2012
Group: Dawi Zharr
Market Rep: 4
Slaves: 45
RE: K'daai destroyer conversion stonehorn/thundertuskbrotsorrow 04-18-2012
Love the conversion..... Can you give some details as to what you did in the modelling prep? I stopped playing WH when the dwarfs got their new book in version 6, these new models are unfamiliar to me.
Also, are you nervous using a 4 legged beast for the destroyer that you are now using a larger base than necessary for a rare? or would all monstrous large monsters be using this base size (can you tell im still thinking that base size determines unit strength? )
04-18-2012 11:51 PM |
Smog
Chaos Dwarf Warrior
Group: Dawi Zharr
Market Rep: 0
Slaves: 26
RE: K'daai destroyer conversion stonehorn/thundertuskSmog 04-19-2012
In the case of the Destroyer, the large base size is actually a bonus since you can hit more models with the blazing body rule. Besides, I think it says in the rulebook that you are supposed to put it on the same base size as the arachnorok.
04-19-2012 02:18 AM |
Hashutcopper
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 3
RE: K'daai destroyer conversion stonehorn/thundertuskHashutcopper 04-19-2012
Thanks for the coments. The rule book states that K'daai destroyer must be on the larger sized base.
The prep for the model was farely simple but long. I had to cut back alot the fur and excess until the body was cut down enough to built up the layers of green stuff, and use GW sculpting tool to press in the lava cracks and smooth the ends to a close. Semi sett armour plate was placed on and sheilds were glued and green stuffed on once greenstuff layers were set. Stonehorn horns were removed and cut down thundertusk horns were pinned and green stuffed on top of the head. Wire was bent into shape and super glued in the mouth then greenstuffed over and the the wire out of the mouth was green stuffed around. Had to pin the head on as it wouldn't fit properly and the gap was greenstuffed. Flames were also greenstuffed on the face. The tail was cut down pinned and attached later. Then a few other little things.
Big job
This post was last modified: 04-19-2012 06:46 AM by Hashutcopper.
| 04-19-2012 06:45 AM |
brotsorrow
Chaos Dwarf Hero
Group: Dawi Zharr
Market Rep: 4
Slaves: 45
RE: K'daai destroyer conversion stonehorn/thundertuskbrotsorrow 04-19-2012
Wow a lot of prep went into just getting the model for your first set of pics before painting. Thanks for the guide, this may be a project later in the summer, before i go back to school in september.
And thanks for the clarification on bases.
04-19-2012 09:50 AM |
tvandyke
Chaos Dwarf Hero
Posts: 217 - Aug 2009
Group: Dawi Zharr
Market Rep: 0
Slaves: 148
RE: K'daai destroyer conversion stonehorn/thundertusktvandyke 04-19-2012
Big job
Very nice conversion. It's fun seeing everyone's interpretation. It will be really interesting to see what Forgeworld eventually comes up with.
| 04-19-2012 10:47 AM |
The_Bear_in_the_Hat
Posts: 111 - Nov 2010
Group: Dawi Zharr
Market Rep: 0
Slaves: 16
| 04-19-2012 11:40 AM |
Kronosv13
Chaos Dwarf Warrior
Group: Dawi Zharr
Market Rep: 1
Slaves: 17
RE: K'daai destroyer conversion stonehorn/thundertuskKronosv13 04-24-2012
That is one bad a.. K'daai. The painting looks dark and brooding, very good.
04-24-2012 11:37 AM |
