Post Reply  Post Thread
Scale Armour Sculpting (with video)!
Author MessageScale Armour Sculpting (with video)!
Grimstonefire
The Magician Technician
Posts: 6,404 - Feb 2007
Group: Retired Staff
Market Rep: 24
Slaves: 1363
Best Overall Member - 2009 Golden Hat  - Gold x2 Artisan's Contest - Gold Word of Hashut - Contributor Golden Hat - Silver Veteran Medal - Gold Best Overall Member - 2010 Hellsmith - Bronze Golden Hat - Bronze x2
Post: #1
Scale Armour Sculpting (with video)!Grimstonefire 11-01-2007
A first for me to do a video.��The quality isn't great (as expected), but for the specific steps I wanted to show it came out better than expected.
STEP 1:��PREPARE THE MODEL
In order to sculpt scale mail effectively, it's much easier if its on a flat surface.��Also, if you are using Dwarf bodies and plan to keep the trim around the armour intact, you needs to prepare it properly.
To do this, gently scrape away the existing chainmail using a hobby knife.��You may not be able to do this with a massive craft knife, I use a slim scalpel tool.
STEP 2:��ADD A LAYER OF GREENSTUFF
To do scale mail you need a decent thickness of greenstuff.��By this I mean enough to sculpt 'layers' of scale, but not enough that it bulges out over the trim going round the armour.
Get this part right and its a lot easier later on.��Sculpt it too thin and the scales are too lumpy with the texture underneath.
STEP 3:��DRAW THE LINES OF SCALES
This step basically means you draw a line with a craft knife to split it up into however many layers of scale you want,��I'm using the Dwarf Miners bodies and generally stick to 3 layers.��On a couple of bodies I do 4 layers.
STEP 4:��'TUCK' THE LINES OF SCALE UNDER EACH OTHER
Scale mail works so effectively because the scales overlap.��In order to represent this on a model you need to press down each row on the upper half so that it is lower than the layer above.
STEP 5:��SPLIT EACH ROW INTO INDIVIDUAL SCALES
Use a sculpting tool to press down on each row, effectively splitting it into the scales.��Do them in such a way as represent the pattern below.
STEP 6: PRESS THE CURVE ONTO THE BOTTOM OF EACH SCALE
You could just leave the scale mail as it is, with the armour being made of rectangle pieces of metal.��Some 'die hard' traditionalists like me choose to have them curved on the bottom.
I knew this would be easier to explain with a video.Wink
http://www.youtube.com/watch?v=nFRJZqmJw9M
STEP 7:��FLATTEN THE SCALES
A step that IMO is often overlooked.��Basically this means very gently pressing down onto each scale to make sure it is actually flat.��The steps above can cause them to be a bit rounded.
I cover this in the video.
FINAL PHOTOS
2017 Image Salvage
This post was last modified: 08-10-2017 01:49 PM by Admiral.
11-01-2007 06:30 PM
wallacer
Hashut's cow pimp
Posts: 3,538 - Feb 2007
Market Rep: 4
Slaves: 1046
Artisan's Contest - Bronze Image Gallery Contributor - Bronze Word of Hashut - Contributor Wiki - Major Contributor Blackshard Army Medal - 10000 PTS
Post: #2
RE: Scale Armour Sculpting (with video)!wallacer 11-01-2007
I found the sound quality on the video a bit hard, but the visuals complement Xander's videos nicely.
Army pics: http://www.chaos-dwarfs.com/forum/showth...888&page=1
11-01-2007 07:26 PM
Grimstonefire
Market Rep: 24
Slaves: 1363
Post: #3
RE: Scale Armour Sculpting (with video)!Grimstonefire 11-01-2007
I recorded the sound after the video as an afterthought, narrating whilst it played on my computer.  So I think the background noise is the fan.
I didn't intend to have sound, but it helps I guess.
If I replace it I will definately do the next one in daylight.  The light quality is poor really.
Still, as a spontaneous thing using my camera I am pleased.
11-01-2007 07:37 PM
wallacer
Hashut's cow pimp
Market Rep: 4
Slaves: 1046
Post: #4
Yeah, I thought the camera work itself was fine.
Maybe next time you do the sound try to move the monitor and microphone away from the computer a bit?
11-01-2007 07:53 PM
Kera foehunter
Zharr Nauggund Alpha Female
Posts: 8,568 - Sep 2007
Group: Dawi Zharr
Market Rep: 14
Slaves: 153
Post: #5
RE: Scale Armour Sculpting (with video)!Kera foehunter 11-02-2007
grims a movie star too .Yea!!!! great job grims i wounder what the straw was use for ..
Great job all around
11-02-2007 05:53 AM
AGPO
BOAR CENTAUR!
Posts: 3,130 - Mar 2007
Market Rep: 0
Slaves: 1271
Post: #6
RE: Scale Armour Sculpting (with video)!AGPO 11-03-2007
Thanks Grim, my scale mail work was always a tad shoddy, but this clears a few things up for me! More sculpting videos people. How about a series on doing faces from someone?
Check out my blogs!:
Chaos Dwarfs (6/6/09)Other shiny things (13/11/11)
I follow the Grumpy But Responsible Gamers' Charter. Join us!
Sojourn Wrote:
FYI Wilmark, the only alcohol I'm drinking is from that bucket
11-03-2007 09:01 AM
Grimstonefire
Market Rep: 24
Slaves: 1363
Post: #7
RE: Scale Armour Sculpting (with video)!Grimstonefire 11-03-2007
Faces I don't think requires a video.  There are several good guides out there already.  I will look for some links to add to our sticky.
11-03-2007 09:05 AM
AGPO
BOAR CENTAUR!
Market Rep: 0
Slaves: 1271
Post: #8
Yeah if you could, I'm completely lost in that department - its why I sculpt so many wraiths!
11-03-2007 09:10 AM
Kera foehunter
Group: Dawi Zharr
Market Rep: 14
Slaves: 153
Post: #9
RE: Scale Armour Sculpting (with video)!Kera foehunter 11-03-2007
So no hollywood grims i thought you did good .Better than i cuuld do
11-03-2007 07:13 PM
Tok
Unregistered
Post: #10
RE: Scale Armour Sculpting (with video)!Tok 11-04-2007
Got any tips on how to make heavier armor on the arms?
11-04-2007 04:06 PM
Quote this message in a reply
Grimstonefire
Market Rep: 24
Slaves: 1363
Post: #11
RE: Scale Armour Sculpting (with video)!Grimstonefire 11-04-2007
On the miner arms?  Hmm.  I would just sculpt something appropriate, but some bits of small plasticard bent slightly and glued on might work?  A simple strap around underneath to show how its held on.
Another idea being to add a little bit of scale mail over the shoulders.
11-04-2007 04:58 PM
Tok
Unregistered
Post: #12
RE: Scale Armour Sculpting (with video)!Tok 11-05-2007
Could you give a tutorial for those ideas too?
11-05-2007 01:10 AM
Xander
Chaos Dwarf Ambassador
Posts: 4,757 - Feb 2007
Group: Hashut's Admin
Market Rep: 7
Slaves: 504
Post: #13
RE: Scale Armour Sculpting (with video)!Xander 11-05-2007
You rock, Grim!  Well done.  Lovely tutorial. Happy
Join us on the new forum. Come help us test it out!
https://discourse.chaos-dwarfs.com
11-05-2007 01:11 AM
wallacer
Hashut's cow pimp
Market Rep: 4
Slaves: 1046
Post: #14
RE: Scale Armour Sculpting (with video)!wallacer 11-05-2007
Is this going to be stickied or something so it will be easy for people to find?
11-05-2007 03:41 PM
Xander
Market Rep: 7
Slaves: 504
Post: #15
It'll be added to the compiled list. Happy
11-05-2007 03:50 PM
Tok
Unregistered
Post: #16
RE: Scale Armour Sculpting (with video)!Tok 11-06-2007
I'v tried this on some, i think i use more greenstuff, i haven't scraped away the "chainmail" and i used regular cc dwarfs, instead of miners.
Tips are welcome..
I want them to have heavier helmets, armor on the arms and gloves. Not sure how to make any of those yet..
http://www.bork.sverok.net/cpg/albums/us...warfa2.jpg
http://www.bork.sverok.net/cpg/albums/us...dwarfa.jpg
11-06-2007 02:53 PM
Grimstonefire
Market Rep: 24
Slaves: 1363
Post: #17
RE: Scale Armour Sculpting (with video)!Grimstonefire 11-06-2007
Looking nice there Tok.  Only thing I would suggest is to try and flatten each scale a bit for the next ones.  They look slightly rounded, which is not necessarily bad. Wink
11-06-2007 07:04 PM
Tok
Unregistered
Post: #18
RE: Scale Armour Sculpting (with video)!Tok 11-07-2007
In which of your stages should i try flattening the scales?
And, how do i flatten them?
Thanks.
This post was last modified: 11-07-2007 11:04 AM by Tok.
11-07-2007 06:31 AM
Grimstonefire
Market Rep: 24
Slaves: 1363
Post: #19
RE: Scale Armour Sculpting (with video)!Grimstonefire 11-07-2007
It would be step 7.
To flatten scales gently press your sculpting tool down flat onto them.
I know some people here use wierd and wonderful sculpting tools, so you would need to find something fairly small to do this with (not a craft knife unless you are very skilled).
Though its not very clear, you can see me doing this in the video.
This post was last modified: 11-07-2007 12:02 PM by Grimstonefire.
11-07-2007 12:01 PM
Tok
Unregistered
Post: #20
Ah, that part, now i see, thanks.
What about timing? At what minutes should the diffirent stages be done?
This post was last modified: 11-07-2007 12:10 PM by Tok.
11-07-2007 12:04 PM
Possibly Related Threads...
  Quick 'n' Dirty Lamellar Armour Sculpting Tutorial Admiral 5 1,657 09-12-2017 10:54 AM
Last Post: Admiral
  Flaming Video - Sculpting torches with Green Stuff! Vexxus 12 9,805 09-23-2008 04:31 AM
Last Post: Bassman
View a Printable Version
Send this Thread to a Friend
Forum Jump:
