Post Reply  Post Thread
Arena of War: "balancing" Age of Sigmar
Author MessageArena of War: "balancing" Age of Sigmar
Thommy H
Zhatan the Black
Posts: 6,572 - Aug 2007
Group: Immortals
Market Rep: 3
Slaves: 536
Wiki - Major Contributor Word of Hashut - Contributor Image Gallery Contributor - Gold Gold Army Medal - 4000 PTS Artisan's Contest - Gold x2 Veteran Medal - Bronze Best Contributor - 2011 Artisan's Contest - Bronze
Post: #1
Arena of War: "balancing" Age of SigmarThommy H 09-27-2015
*Sighs*
Look, I'm in the camp of those that think Age of Sigmar is, generally, a Good Thing. I think the system and its aims are sound, and the basic rules already contain a balancing mechanism in the form of the deployment mini-game and the sudden death victory conditions. But I do sympathise with the people who recoil from such wishy-washy notions after a lifetime of playing a game in which "army building" was a major part of the experience.
And I think that GW could have dodged a huge amount of criticism if they'd merely acknowledged this change in philosophy and explained why they were changing this basic premise. Or just chucked out a token "here's how you put together an army" section in the rules or something, and let people dissect that. But just throwing out the baby with the bathwater has obviously rubbed a huge amount of people the wrong way.
Anyway, as is often the case when GW leave something undone, I've decided to step in and offer my own solution. I'm nice like that. There are tons of comp systems floating about online and improvised by tournament organisers, many of which are longer than the actual rules. I want to embrace what AoS is all about and keep things as simple and elegant as possible - I set myself a target of a single page, and I've achieved that.
The concept is very simple: the warscrolls, by their nature, involve a limitation - unit size - and if you examine the rules this manifests in a couple of ways. For example, units intended to make up the core of forces get advantages for having large sizes, while elite units don't. My belief, therefore, is that each warscroll is balanced, in and of itself, against every other. Now, this is patently untrue in many cases - Nagash is better than a Goblin Warboss - but it's true enough to form a kernel of an idea. If both sides pick the same number of warscrolls, the battle should be balanced (for a given definition of "balanced").
I've added some wrinkles. The main one is that larger units count as more warscrolls for army selection purposes, but apart from that I also limit heroes, monsters and war machines. And any heroes that are also monsters or war machines are more costly too (that means Nagash, Greater Daemons, etc.). But the big thing, the really important thing, is that summoned units have to be part of your army list. I think this solves the big problem that many people have with AoS "out of the box" - there's an assumption (based on previous editions of Warhammer) that summoned, raised, etc. units are "free". That's what makes Nagash powerful, because you can show up with him on his own and then create a whole army from nothing. These rules, dubbed Arena of War, prevent that.
Anyway, this post is at risk of becoming longer than the rules themselves. Consider this an alternative to eyeballing armies to check they're about even. It's not intended to provide an AoS equivalent to points costs in previous editions; it's not detailed enough for that. I think if GW had published something like this from the beginning though, it would have made things easier on them. I'd be interested to hear your thoughts.
Attached File(s)
.pdf File  Arena of War.pdf (Size: 430.47 KB / Downloads: 17)
Serial Writist - lots and lots of short fiction, written by me, regularly updated.
My models:
The Legion of Astragoth | The Dark Crusade of Mousillon | The Destroyer Cult | Les Défenseurs du Béniterre | Storm Over Béniterre | Force Belial
My rules:
Chaos Dwarfs Warscroll Compendium
This post was last modified: 09-29-2015 05:18 PM by Thommy H.
09-27-2015 01:16 PM
Abecedar
Curmudgeon of Hashut
Posts: 4,616 - May 2010
Group: Immortals
Market Rep: 14
Slaves: 1715
Post: #2
RE: Arena of War: "balancing" Age of SigmarAbecedar 09-27-2015
It looks very good.  I am certainly no where near even competent to do any critiques but your work is looking and reading more and more "professional" each time.
Army Blog
Short Stories
Legend of Lord Kvackd'up
Zhek'dars tales  =  tbf.
09-27-2015 09:37 PM
Gothnomicon
Hobgoblin
Posts: 11 - Jun 2012
Group: Dawi Zharr
Market Rep: 0
Slaves: 4
Post: #3
RE: Arena of War: "balancing" Age of SigmarGothnomicon 09-28-2015
Misspelling on the first sentence in the first paragraph - "Unlike in ordinary games of Warhammer: Age of Sigmar, Area" (<- should probably be Arena).
Also regarding the math on 'Any number of Models' call out. If you divide 10 by the number of wounds for a 3-wound model you would get 3.333. Your next statement says to round any fractions up, so it would be a minimum size of 4, not three as you state. IDC, which way you go, but it should be consistent.
If you can make the room, I think your final example army section should include an example that shows the use of your warscroll battalions rule. The warscroll battalions section is a bit hard to understand at first. I think I figured it out, but the example would be helpful.
I really like the Arena of War concept, it is nearly the same as what I'm using for a home-brew comp for AoS anyway. Keep up the good work!
Goth
09-28-2015 09:02 AM
Thommy H
Zhatan the Black
Group: Immortals
Market Rep: 3
Slaves: 536
Post: #4
RE: Arena of War: "balancing" Age of SigmarThommy H 09-28-2015
Yep, good spots. Fractions should be rounded down, not up - I reversed some of the phrasing in that section during editing and obviously left some of the old wording intact!
I agree about the battalions. It's one of those things that's easy to explain, but hard to write rules for. The idea is that you still have to pay for the units' warscrolls, but ignore the limits on heroes, monsters, war machines and scenery. So a battalion with 10 heroes would be legal in a 10-warscroll army because it represents a special formation.
I'll try to figure out a better way of succinctly explaining that. Maybe an example would be useful. Thanks!
My models:
My rules:
09-28-2015 09:40 AM
Thommy H
Zhatan the Black
Group: Immortals
Market Rep: 3
Slaves: 536
Post: #5
All right, updated version attached to the first post. Reworded basically everything and hopefully it all makes sense now...
Explaining what I meant about the warscroll battalions was absurdly difficult, and all I could really do was add a lengthy example. At one point I was dividing units into categories and all sorts to try to get the idea across elegantly. It's so easy to explain, so hard to put into succinct words. Anyone who thinks AoS was just thrown together needs to try writing something like this in a very limited space. It's an interesting challenge.
My models:
My rules:
This post was last modified: 09-28-2015 06:26 PM by Thommy H.
09-28-2015 06:25 PM
Admiral
Auxilliary Moderator
Posts: 7,257 - May 2011
Group: Hashut's Admin
Market Rep: 10
Slaves: 625
Scribe's Contest - Bronze x3 Best Attitude - 2014 Best Contributor - 2014 Major Prize Sponsor Golden Hat - Bronze x2 Scribe's Contest Veteran Scribe's Contest Silver Hellsmith - Gold Dark Apostle - Silver Best Attitude - 2015 Best Overall Member - 2015 Best Contributor - 2015 Artisan's Contest - Silver x2 Best Overall Member - 2016 Best Contributor - 2016 Artisan's Contest - Gold Best Contributor - 2017 Best Attitude - 2017
Post: #6
RE: Arena of War: "balancing" Age of SigmarAdmiral 09-29-2015
Great to see you're at it, Thommy. We haven't yet tried Age of Sigmar in my hobby group, but whenever we do so I'll be sure to print out your balancing sheet.
News on CDO: Artisan's Contest XXIX - Voting Deadline 27th of February  ...  Etsy shop
Chaos Dwarf Writings:
Fables. Songs. Proverbs. Quotes. Monumental Inscriptions. Religious Texts.
09-29-2015 02:38 AM
Gothnomicon
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 4
Post: #7
RE: Arena of War: "balancing" Age of SigmarGothnomicon 09-29-2015
Doh, still missed fixing 'Area of War' to 'Arena of War' in the first sentence. LOL!
Sorry, I've worked closely with an OCD technical writer for years, I can't help but report these things...
Goth
09-29-2015 07:24 AM
Gothnomicon
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 4
Post: #8
Gothnomicon Wrote:
- Still need to fix 'Area of War' to 'Arena of War' in the first sentence
- Treelord s/b Treeman in the examples
Also, since I have a Wood Elf army, I'll also comment on the example list. I'd swap the 2nd unit of (10) Dryads for a unit of (6) Tree Kin for the same two warscrolls. I know it is just an example. The 10 dryads are not enough models to qualify for the Impenetrable Thicket special rule.
Still, this is awesome work!
I'm going to update an Excel spreadsheet that I've started to work with your Arena of War rules. It allows you to put in the number of models that you want to field, and it will calculate your warscroll cost. I'll share it back to the community when I get it done.
Goth
09-29-2015 07:45 AM
Thommy H
Zhatan the Black
Group: Immortals
Market Rep: 3
Slaves: 536
Post: #9
RE: Arena of War: "balancing" Age of SigmarThommy H 09-29-2015
Argh - I changed it, but I bet it got undone when I reverted some other more significant change... *grumble grumble*
My models:
My rules:
09-29-2015 07:48 AM
cornixt
Brewer of Daemonic Beer
Posts: 4,271 - Feb 2007
Market Rep: 0
Slaves: 1337
Gold Army Medal - 4000 PTS Wiki - Major Contributor Word of Hashut - Contributor Artisan's Contest - Gold Best Attitude - 2011 Artisan's Contest - Silver x2 Veteran Medal - Bronze Artisan's Contest - Bronze
Post: #10
RE: Arena of War: "balancing" Age of Sigmarcornixt 09-29-2015
"Minimum allowed or fewer"? How could someone take less than the minimum? Or is it a very soft minimum?
Like a Great Taurus in a Cathay shop.
There's a lot more in the wiki than you think, check out the wiki contents
09-29-2015 11:59 AM
Thommy H
Zhatan the Black
Group: Immortals
Market Rep: 3
Slaves: 536
Post: #11
The rules allow you to include an under-strength unit if you don't have enough models, actually, but I take your point and will rephrase...
My models:
My rules:
09-29-2015 01:43 PM
Thommy H
Zhatan the Black
Group: Immortals
Market Rep: 3
Slaves: 536
Post: #12
Corrected version uploaded. Treelord is accurate, btw - it's what Treemen are called now.
My models:
My rules:
09-29-2015 05:19 PM
Gothnomicon
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 4
Post: #13
RE: Treelord
Wow, they changed it when they re-based to oval bases. I actually checked the GW warscroll on my computer, but I guess they are stealth releasing the warscrolls with changes as well.
Cool, thanks!
09-29-2015 08:25 PM
Thommy H
Zhatan the Black
Group: Immortals
Market Rep: 3
Slaves: 536
Post: #14
RE: Arena of War: "balancing" Age of SigmarThommy H 09-30-2015
The Wood Elves compendium still says Treeman, but it got its own warscroll when they released the first big hardback, and that says Treelord. Same rules though.
My models:
My rules:
09-30-2015 02:39 AM
View a Printable Version
Send this Thread to a Friend
Forum Jump:
