Post Reply  Post Thread
Plastic card and glue?
Author MessagePlastic card and glue?
tjub
Prophet of Tjubshut
Posts: 4,744 - Oct 2008
Group: Immortals
Market Rep: 13
Slaves: 1559
Post: #1
Plastic card and glue?tjub 05-13-2019
So what's the best way to glue plastic card? I used GWs plastic glue but didn't seem to "melt" together like on plastic miniatures. Is super glue better? What do you people use? Happy
Intro to 15mm Kings of War
05-13-2019 11:24 AM
Nicodemus
Grand Imperious Sorcerer of the Forge
Posts: 2,618 - Jun 2009
Group: Hashut's Admin
Market Rep: 40
Slaves: 1259
Word of Hashut - Contributor Chaos Dwarf Radio - Contributor Veteran Medal - Silver Best Attitude - 2010 Gold Army Medal - 4000 PTS Wiki - Major Contributor Image Gallery Contributor - Bronze Best Overall Member - 2011 Golden Hat - Bronze Best Overall Member - 2013 Photobucket Migration Photobucket Migration Exceptional Help
Post: #2
RE: Plastic card and glue?Nicodemus 05-13-2019
I've had terrible luck with the GW product and honest cannot recommend it except as a quick in-the-moment solution to adhere plastic together. Their plastic glue becomes increasingly brittle over time and will eventually giveway.  My locomotive that I had made was done with a lot of GW plastic glue and after 2 years all of the seams and joints popped apart as soon as I picked it up... and they broke along edges that I wasn't touching and weren't supporting any weight.
Dichloromethane (aka DCM, methylene chloride, solvent cement, plastic weld, etc) is very good. It's highly volatile and is metabolized in the body to carbon monoxide... that being said as long as you work with small quantities of the amounts you'd need for hobby work and don't leave it open under your nose for hours on end you'll be totally fine.  It's not legal here in Canada for direct sales but respectable hobby companies will have ways of getting it (model railroad groups, etc in your area will probably know where to find it and you may be able to buy it online.
Another one is methyl ethyl ketone (aka MEK or 2-butanone). It also works well.
Any of these types of solvents will dissolve a small amount of surface plastic and allow you to weld the pieces together. After a few hours (longer if you have used a lot of solvent, the surfaces are large, and/or the weld joints are trapped inside a model and can't easily "dry") you'll have a model that's fused as if it was a single piece of plastic.
I've sworn off GW plastic glues entirely and everyone else should too Takes Hat off  The stuff that I use (DCM and MEK) is cheaper than the GW stuff, works better, you get more of it, and therefore it lasts MUCH longer too. Really no downside at all!  My first time using it was like my first time using a wet palette - "Why haven't I been doing this since the beginning!?!?"
Edit: superglue (aka cyano acrylate) works great too, but only a very small amount of it adheres and bonds to the surface, then the rest of the cyano acrylate builds up on top of that adhered layer. If you're going to glue a long seam (like the edges of two pieces of plasticard) then this isn't for you.  If you're going to put an am into a socket on a ball-groove on the shoulder of a model and have a big surface area then this works just as well as any of the plastic weld stuff and you'll generally break the arm at some other point before you'll break the glue joint apart. Again though, long thin edges alone won't be good for this glue unless you have some kind of internal or backing support across the seam.
Nicodemus' adage: "It is not enough to bash in skulls, we must bash in minds!"
Nicodemus' Forge of Unfinished Business (Chaos Dwarf Blog) and Non-Dawi'Zharr Blog
Warhammer Quest & Dreams of Hashut (3D Tile Creation Blog - Dawi Underway & More!!)
Chaos Dwarf 'Quest Blog (Download the Warhammer Quest: Chaos Dwarfs Roleplay Book )
Warhammer Quest: Chaos Dwarf Expansion (Board Game Geek)
This post was last modified: 05-13-2019 11:55 AM by Nicodemus.
05-13-2019 11:51 AM
tjub
Prophet of Tjubshut
Group: Immortals
Market Rep: 13
Slaves: 1559
Post: #3
RE: Plastic card and glue?tjub 05-14-2019
Thanks for a great review Nico! Takes Hat off
05-14-2019 12:14 AM
Admiral
Auxilliary Moderator
Posts: 7,282 - May 2011
Market Rep: 10
Slaves: 588
Post: #4
RE: Plastic card and glue?Admiral 05-14-2019
Very useful to know Nico! Cheers!
Etsy shop
05-14-2019 07:05 AM
Jasko
Chaos Dwarf Sorcerer
Posts: 320 - Nov 2018
Group: Dawi Zharr
Market Rep: 1
Slaves: 55
Post: #5
RE: Plastic card and glue?Jasko 05-16-2019
Great in-depth analysis, Nico!
So I still use regular plastic glue. At some point I was also dissatisfied with GW plastic glue and now use one from UHU, works pretty well. One has to be sure that the plastic card is polystyrene, though, some plastic glues don't work with polyethylene or polypropylene. I've also used super glue and even pretty basic craft glue (this thick white stuff which gets transparent after drying)
Chaos Dwarf Showcase: Legion of Jaskorh
Offtopic Showcase: Night Goblin Auxiliaries
Hobby Blog: ijasko @ Wordpress
05-16-2019 07:36 AM
Possibly Related Threads...
  Plastic card cutter tjub 1 673 01-09-2019 04:38 AM
Last Post: bas_2312
  Working with plastic card tjub 8 1,169 02-06-2018 02:38 PM
Last Post: Willmark
  What glue for titan forge models TheHoodedMan 8 2,744 09-24-2014 07:07 AM
Last Post: Admiral
  Plastic Card Da Crusha 4 1,531 06-22-2012 07:25 PM
Last Post: Da Crusha
  Stripping Glue and Paint Fallen246 12 5,017 11-22-2010 09:42 PM
Last Post: G.2
View a Printable Version
Send this Thread to a Friend
Forum Jump:
