Post Reply  Post Thread
quidamcorvus' Candle Tutorial
Author Messagequidamcorvus' Candle Tutorial
Admiral
Auxilliary Moderator
Posts: 7,314 - May 2011
Group: Hashut's Admin
Market Rep: 10
Slaves: 591
Post: #1
quidamcorvus' Candle TutorialAdmiral 10-18-2019
Found this on Warseer:
quidamcorvus Wrote:
In February, on my blog the DansE MacabrE, I published a tutorial in which I showed you how to make candles with a toothpick, copper wire and Wikol glue. The guide can be found HERE.
However, today I have for you another way to make candles.
The idea is not mine, some time ago I saw a short photo tutorial on the AlienLAB Creator, site, and while building the Grimnir Monument to Warheim FS I decided to try this way to make several candles of different sizes.
To make candles you will need multi-stranded electric wires, rather thin ones, and several thicknesses will add variety to the final effect.
Depending on your needs, cut the wires to the length you want, in my case it was about 10 mm.
Then strip the insulation from the wires approximately 1/3 of the length and twist the wires of the wire like a candle wick.
Now you have new candles or dynamite sticks.
If you need burned candles, use Wikol glue to make the flowing wax. Apply a wood glue with a thin pin or the tip of a paper clip to the candles and around the base, and after drying you will get the effect of solidified wax. Leave the candles to dry for several minutes.
And it's ready.
Etsy shop
10-18-2019 12:18 AM
Zanko
Prime Frurndar of Hashut
Posts: 3,374 - Dec 2008
Group: Immortals
Market Rep: 11
Slaves: 1394
Blackshard Army Medal - 10000 PTS Image Gallery Contributor - Blackshard Word of Hashut - Contributor Veteran Medal - Gold Diplomat Medal - Bronze Major Prize Sponsor Photobucket Migration Exceptional Help Golden Hat - Gold Golden Hat - Bronze
Post: #2
RE: quidamcorvus' Candle TutorialZanko 10-18-2019
Cool find Admiral! Takes Hat off Thanks for sharing! Cheers!
                     Hashut!
         "Frurndar are still existing!"
               The Lizard King
10-18-2019 05:10 AM
Abecedar
Curmudgeon of Hashut
Posts: 4,626 - May 2010
Group: Immortals
Market Rep: 14
Slaves: 1715
Post: #3
RE: quidamcorvus' Candle TutorialAbecedar 10-18-2019
I used to be a sparkie and I'd never have thought of doing this wire wire.
Thanks heaps.
27 June 17(ouchy); 15 June 17
Army Blog
Short Stories
Legend of Lord Kvackd'up
Zhek'dars tales  =  tbf.
10-18-2019 06:07 AM
View a Printable Version
Send this Thread to a Friend
Forum Jump:
