Post Reply  Post Thread
The Remarshalling of Uzkulak
Author MessageThe Remarshalling of Uzkulak
Dînadan
Sardonic Daemon of Hashut
Posts: 2,267 - Nov 2013
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #1
The Remarshalling of UzkulakDînadan 11-12-2019
So, after a long break from working on my Chaos Dwarf Army I’ve decided to return to it and refresh it, and as part of that refresh I’ve decided to wipe the slate and start a new blog.
Spent today starting to work it by starting on a couple of characters.  First up the army Overlord:
The base model is the Greywater Fastness Warden (Belegar Ironhammer to us longbeards) with the hat from a 4th ed Chaos Dwarf Hero, as are the axe blades (had one spare blade from a conversion I made years ago to be a CD BloodBowl coach) and the shield from a plastic Ancient Greek hoplite.  My plan is to sculpt a nose, pair of tusks and a lower lip over the mask and sculpt coils over the beard and scale armour in place of the mail.  I’m also considering lopping off his shins to make him shorter as he’s considerably taller than the old Big Hats who will be making up the bulk of the army.  I’ll probably also add a skull or other such ornament on top of the hat.
Next is the BSB:
Base is the hero that so kindly donated his hat and axe to the Overlord.  I was initially considering using him as the Overlord but couldn’t find something satisfactory to use as a Daemonsmith, so decided to get the aforementioned plastic to use as the Overlord and bumped this guy down to BSB (and the Champion mini I was planning on using as the BSB got reassigned to be said Daemonsmith).  The replacement weapon is from the Ironbreaker/Irondrakes kit (who I’ll be using to kitbash a unit of Immortals), with the plan to be to incorporate the hammerhead from the Belegar mini on the reverse of the axe.  Not sure where the shield is from; think it might be an old Orc shield.  Originally I was going to have him holding a standard but then decided as this mini still had the back banner that these old CD characters had I’d use that as the battle standard instead, but as the poles weren’t perfectly straight I’ve decided to opt to replace them with wire pikes (I’ll cut the length down to a more suitable size; might also remove the pike tips or cover them with something as I know from personal experience those things can be painful if you’re not careful, lol).  Hat is obviously a push pin and may or may not be a place holder, haven’t decided yet.
That’s it for now in regards to pictures, will add more as I do more work.  In the pipeline are:
A Sorcerer-Prophet on palanquin (unlikely to take to the field much, but doing it because I think it’ll be a nice conversion)
A Sorcerer-Prophet on foot (uses an AoW Runepriest; is from the previous iteration of my army and for the most part is done, will just be repositioning his arms/staff so I can enlarge his hat so as not to be overshadowed by the common grunts)
A Daemonsmith as mentioned previously (will be replacing the left hand which is currently sculpted to hold a shield; haven’t fully decided what it’ll be replaced by yet)
A second Daemonsmith (no conversion work needed, will just be repainted from the previous colour scheme I used on him)
A unit of warriors with great axes (the old plastic CDs, some with hat swaps with the blunderbusses; conversion work was done previously so will just need painting)
A unit of warriors with axe and shield (to be converted from the BfSP dwarfs)
Two units of blunderbusses (some with hat swaps with the plastic warriors as mentioned above; for the most part will just need repainting although the command group for one still needs to be converted)
Some Bazukas (to be purchased from Admiralty Miniatures when I have the funds; the spare hats will be used on the axe and board unit)
A Deathshrieker (using the 4th ed Death Rocket mini; using as is with the addition of an old BB CD as the third crewman)
A unit of Immortals (converted from Ironbreakers/Irondrakes with the great weapons from hammerers)
A Dreadquake Mortar (current plan is to use the conversion I made for the previous iteration of my army; never got around to painting it.  Will need crew converted unless I luck out and manage to snag some extra Death Rocket crew off eBay)
A Siege Giant (using a limited edition resin casting of a Mantic Ghoul; it’s a 3-up they sold many years back that I won off of eBay years ago)
I also have a boatload of 4th ed goblins who will be becoming hobgoblins for a 1k Hobgoblin Army.  In the distant future I’m hoping to expand it up to 2k with a bunch of hobbos on wolves; need to get the CDs and the hobbos on foot done first, then need to source minis with the right look.
And on top of all this, I backed Admiralty Miniature Tjubgob Kickstarter so will have a boatload if 15mm Tjubgob and Tjublings arriving before long.
11-12-2019 09:34 PM
tjub
Prophet of Tjubshut
Posts: 4,736 - Oct 2008
Group: Immortals
Market Rep: 13
Slaves: 1549
Post: #2
RE: The Remarshalling of Uzkulaktjub 11-13-2019
Wonderful, looking forward to this! What do you plan to use them as? Or rather what system I guess? Happy
...that BSB looks a bit dangerous IMO, quite an eye poker you have created there. Shock
Intro to 15mm Kings of War
11-13-2019 01:27 AM
tjub
Prophet of Tjubshut
Group: Immortals
Market Rep: 13
Slaves: 1549
Post: #3
Oh, cool that makes me glad. I hope to see another army the size of Duncans! Cheers!
What are your plans for them?
11-13-2019 01:28 AM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #4
RE: The Remarshalling of UzkulakDînadan 11-13-2019
Thanks Tjub.  The 28mm stuff is going to be used for 8th ed Fantasy.  My current plans for the 15mm stuff is Saga Age of Magic*, although I plan on basing them in such a way to give some flexibility (I’m planning on putting them on 10mm bases, and then putting three onto a 20mm base; ruleswise each base of three will only be one model, but by multibasing it’ll look more impressive).
*dependant on being able to get others at my club to do 15mm, so they might end up just being a little *ahem* side project just for fun.
11-13-2019 07:23 AM
Admiral
Auxilliary Moderator
Posts: 7,256 - May 2011
Group: Hashut's Admin
Market Rep: 10
Slaves: 625
Scribe's Contest - Bronze x3 Best Attitude - 2014 Best Contributor - 2014 Major Prize Sponsor Golden Hat - Bronze x2 Scribe's Contest Veteran Scribe's Contest Silver Hellsmith - Gold Dark Apostle - Silver Best Attitude - 2015 Best Overall Member - 2015 Best Contributor - 2015 Artisan's Contest - Silver x2 Best Overall Member - 2016 Best Contributor - 2016 Artisan's Contest - Gold Best Contributor - 2017 Best Attitude - 2017
Post: #5
RE: The Remarshalling of UzkulakAdmiral 11-13-2019
Nice to see you're fully back now! Takes Hat off
Nice use of the hoplon, and good plan to add a skull to the top of the banner poles. Great conversions so far!
News on CDO: Artisan's Contest XXIX - Voting Deadline 27th of February  ...  Etsy shop
Chaos Dwarf Writings:
Fables. Songs. Proverbs. Quotes. Monumental Inscriptions. Religious Texts.
11-13-2019 07:58 AM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #6
Thanks Admiral. Happy
11-13-2019 08:11 AM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #7
Managed to get a little more work done on these guys today.  Glued the overlord’s body, shield and weapon together and glued the hat to his head; added a row of skulls to the top and crowned it with one of the bull head icons from the back banner.  I also removed the shins to make him the same height as the BSB.
Assembled a new back banner to be the BSB’s battle standard using the shield/backpack of the regular back banner, wire pikes, chain, some Skaven shields and skulls from the GW skull kit.  Have also glued his weapon together.
This post was last modified: 11-13-2019 05:06 PM by Dînadan.
11-13-2019 05:05 PM
Uther the unhinged
Great Taurus
Posts: 767 - Jun 2017
Group: Dawi Zharr
Market Rep: 0
Slaves: 672
Scribe's Contest Silver Best Overall Member - 2018 Artisan's Contest - Silver
Post: #8
RE: The Remarshalling of UzkulakUther the unhinged 11-13-2019
Oh man. I love the suspended skull back banner. Inspired. Also the hat body ratio for the overlord is perfect with the skulls. Uzukalak ‘never knowingly under hatred’.
An AoS creation myth: http://www.chaos-dwarfs.com/forum/showth...?tid=17414
Uthers’ legions of Hashut: http://www.chaos-dwarfs.com/forum/showth...?tid=17110
Bosom of Hashut: http://www.chaos-dwarfs.com/forum/showth...?tid=18010
11-13-2019 05:25 PM
Uther the unhinged
Great Taurus
Group: Dawi Zharr
Market Rep: 0
Slaves: 672
Post: #9
Under hatted. Hashut I hate predictive text!!!
11-13-2019 05:26 PM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #10
Thanks Uther.
11-13-2019 05:27 PM
tjub
Prophet of Tjubshut
Group: Immortals
Market Rep: 13
Slaves: 1549
Post: #11
RE: The Remarshalling of Uzkulaktjub 11-14-2019
I like all the skulls, good call there. And dark! Takes Hat off
11-14-2019 01:12 AM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #12
RE: The Remarshalling of UzkulakDînadan 11-14-2019
Well they do come from the Great Skull Land, so I’m sure they’ve got plenty laying around. Tongue Wink
11-14-2019 01:22 AM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #13
RE: The Remarshalling of UzkulakDînadan 02-12-2020
Small update; was in a bit of a hobby rut over the last few months so didn’t get anything done, but having slowly been getting back into the swing of things last few days.
02-12-2020 06:02 AM
Vapo
Hobgoblin
Posts: 21 - Mar 2017
Group: Dawi Zharr
Market Rep: 0
Slaves: 27
Post: #14
RE: The Remarshalling of UzkulakVapo 02-12-2020
Wow, that's looking great, well done!
02-12-2020 12:48 PM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #15
Thanks
02-12-2020 01:26 PM
ashur
Bull Centaur
Posts: 411 - May 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 90
Post: #16
RE: The Remarshalling of Uzkulakashur 02-12-2020
Great use of the minotaurs' bitz!
Dawi-Zharr of all countries, unite !
minies:
http://www.chaos-dwarfs.com/forum/showth...67#pid8567
Background:
Chaos Dwarfs and Kingdoms of Ind - http://www.chaos-dwarfs.com/forum/showth...#pid289243
The Dragon Isles - http://www.chaos-dwarfs.com/forum/showth...?tid=17958
The edge of the World - http://www.chaos-dwarfs.com/forum/showth...?tid=18055
Estalia:
the nature of Estalia - http://www.chaos-dwarfs.com/forum/showth...?tid=17975
The priestess and the tarasca - http://www.chaos-dwarfs.com/forum/showth...#pid290710
02-12-2020 10:24 PM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #17
Thanks Ashur.
02-12-2020 10:27 PM
Admiral
Market Rep: 10
Slaves: 625
Post: #18
RE: The Remarshalling of UzkulakAdmiral 02-13-2020
Aye, brilliant conversion all over! Love the pose, the skulls on the hat and the bull's head icons. All of it, in fact.
02-13-2020 07:41 AM
Dînadan
Group: Immortals
Market Rep: 0
Slaves: 61
Post: #19
RE: The Remarshalling of UzkulakDînadan 02-13-2020
Thanks Admiral; I can’t really take credit for the pose as it’s the same as the base mini though. Wink
02-13-2020 07:44 AM
Antenor
Chaos Dwarf Warrior
Posts: 58 - Jul 2019
Group: Dawi Zharr
Market Rep: 0
Slaves: 71
Post: #20
RE: The Remarshalling of UzkulakAntenor 02-13-2020
Great conversion. Really like what you did with his face. And what's better than a big hat? An even bigger hat with a bunch of skulls! Big Grin
My Chaos Dwarf army: Azrubal's Host
Side Project: Bronze Age Fantasy
02-13-2020 08:46 AM
View a Printable Version
Send this Thread to a Friend
Forum Jump:
