[Tutorial] Resin Casing, Ishkur-style
| Author |
Message[Tutorial] Resin Casing, Ishkur-style |
Ishkur Cinderhat
The Arch Immortal
Posts: 1,701 - Mar 2007
Group: Immortals
Market Rep: 4
Slaves: 79
[Tutorial] Resin Casing, Ishkur-styleIshkur Cinderhat 04-06-2008
Following the Q&A section of Chaos Dwarf Radio Ep.2, and several messages that were sent to me with questions about mould making and resin casting, I've made a short - but hopefully exhaustive - tutorial.
Note - this is my personal take on making two-part moulds. There are many other ways to pull a mould and many other materials available. See the Useful Hobby Links in this section of the forum for alternative ways.
PART I - Mould Making
[1] What you need: mould-making silicone (regular bathroom / sanitary silicone will not do) a clean plastic cup to mix the silicone, some plasticine / modelling clay (something that will stay soft and not harden if exposed to air), tools, LEGO stones and a release agent. Read the instructions that come with the chemicals!
[2] Now we create the first half of the mould. Embed your sculpts in the plasticine about halfway. You want to make sure that no silicone will go underneath the pieces - the sculpt would be trapped in the silicone. Use the LEGO blocks to define the size and shape of the mould. You can use other stuff as well, but I found LEGO is easy to use, flexible and re-useable. Press some small plugholes into the plasticene.
[3] Cover the whole thing with release agent and leave to dry. Put some on the LEGO blocks as well, the mould will come off more easily then once it's hardened.
[4] Prepare the silicone. I use RTV (room-temperature vulcanizing) silicone rubber. The advantage of this material is that you don't need to heat it or apply pressure to get the vulcanization (i.e. hardening) of the rubber going. The product shown is a simple to use two-part mould making silicone. Other products on the market are one part only where you add a specific amount of a chemical catalyst, usually some drops of special liquid that comes with the set. This is tricky for small quantities of silicone. Imagine you need 2 spoons of material, and then you're supposed to add between 3-6% of the catalyst! The two-part silicone is simply mixed in a ratio of 1:1 and then gently stirred for about 1 minute. Try to not have too much air bubbles in it.
[5] Pour the silicone into the mould form. Small amounts at first, so that no air is trapped between the green and the silicone, then the rest. Take heart, you will see your precious sculpt again! Knock at the table a few times, to help trapped air get to the surface. Then leave the piece to harden. Note that some silicone types will harden quicker in a warm area.
[6] Remove the lego blocks. The plasticene should generally come of quite neatly. Scrape off small residue where necessary. I use an old toothbrush to gently clean up the whole thing with some water. Voilà, you have 50% of your mould!
[7] Rebuild the mould shape with lego blocks. Make sure your greens stay neatly inside the mould and have not come out anywhere. Cover the whole thing with mould release agent again and leave to dry. The mould release is very important at this stage. If you forget it, the next layer of silicone will completely combine with the first one.
Repeat steps [4] and [5]. Remove the LEGO and gently pull the two mould halves apart.
[8] This is the final result. You have your original greens, save and unharmed, ready to be archived. And you have your two-part mould to replicate them as often as you want. Note the plugs that have formed where you pushed the plugholes into the plasticene. These will help to make sure that the two mould halves will align properly.
Part II 'Casting' to follow in the next days.
04-06-2008 01:37 PM |
Pyro Stick
Wizard of the Glen
Posts: 3,409 - Feb 2007
Group: Immortals
Market Rep: 12
Slaves: 766
04-06-2008 01:54 PM |
Hashut's Blessing
The Cakily Blessed One
Posts: 5,789 - Feb 2007
Group: Mods of Hashut
Market Rep: 9
Slaves: 761
RE: [Tutorial] Resin Casing, Ishkur-styleHashut's Blessing 04-06-2008
That makes sense and is so simple. Now, I gotta make something worth replicating Thank you greatly, Ishkur. This is invaluable information. By which I mean uber, not suckish.
Pledge: '09:+83 '10:+116 '11:+118 '12: N/A '13: N/A
04-06-2008 02:22 PM |
WarplockMonkey
Bull Centaur Hero
Posts: 550 - Jun 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
RE: [Tutorial] Resin Casing, Ishkur-styleWarplockMonkey 04-06-2008
WOOOOOOH!
FINALLY someones made a thing showing how to do this!
Does it work well Ishkur? What about with thin peices?
"I dont have TIME fo' pain, the only pain I'VE got time fo' is the pain I put on foos who dont know what time it is" - Terrible Terry Tate
Got an idea for that model you've always wanted to make, but couldn't find the means to convert it? Seen that bit of artwork and thought 'That would be an awesome model'? Give Warplock a PM, any sculpting/converting request considered
Anything Warplock says, instantly becomes fact.
04-06-2008 02:44 PM |
Ghrask Dragh
TeddyMadeMeDoIt...
Posts: 1,386 - Jun 2007
Group: Retired Staff
Market Rep: 6
Slaves: 1035
04-06-2008 03:28 PM |
Kera foehunter
Zharr Nauggund Alpha Female
Posts: 8,182 - Sep 2007
Group: Dawi Zharr
Market Rep: 14
Slaves: 62
RE: [Tutorial] Resin Casing, Ishkur-styleKera foehunter 04-06-2008
thats so great!!!!!Ishkur i personal want to thank you one day im going to try that
thanks kera
Bring back the boar centaurs
04-06-2008 04:18 PM |
Canix
Spirit of Hashut
Posts: 1,175 - May 2007
Group: Immortals
Market Rep: 8
Slaves: 10
RE: [Tutorial] Resin Casing, Ishkur-styleCanix 04-06-2008
Great stuff i will have to try some shields for my second wolfboyz unit jsut neeed to get the bits now
Realists are hampered by there inability to comprehend the true nature of reality
The Pledge 2010:
Bought:11 Painted:12
| 04-06-2008 04:30 PM |
Hammerhand
Bull Centaur
Posts: 492 - Aug 2007
Group: Dawi Zharr
Market Rep: 1
Slaves: 14
RE: [Tutorial] Resin Casing, Ishkur-styleHammerhand 04-06-2008
Thanks ishkur, I'm going to try this soon. Just one question, where do you pour the resin in?
It's been a long time baby, but I guess the mark of Hashut just burns too deep.......
04-06-2008 05:29 PM |
Xander
Chaos Dwarf Ambassador
Posts: 4,448 - Feb 2007
Group: Hashut's Admin
Market Rep: 7
Slaves: 1032
RE: [Tutorial] Resin Casing, Ishkur-styleXander 04-06-2008
Bravo!! Very well done. I await part 2!
Follow CDO on Twitter: Twitter
04-06-2008 05:33 PM |
Ishkur Cinderhat
The Arch Immortal
Group: Immortals
Market Rep: 4
Slaves: 79
04-06-2008 05:44 PM |
Knight Of Awsome
Chaos Dwarf Sorcerer
Posts: 319 - Sep 2007
Group: Dawi Zharr
Market Rep: 3
Slaves: 8
RE: [Tutorial] Resin Casing, Ishkur-styleKnight Of Awsome 04-06-2008
YAY!
I'm going to fallow the same steps when i make my bull centaurs.Whats the brown stuff that you use for a base that you model your green stuff over?
Nice job
04-06-2008 08:40 PM |
torn
Lammasu
Posts: 811 - Jun 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
RE: [Tutorial] Resin Casing, Ishkur-styletorn 04-06-2008
fantastic.my first 2 part mold i forgot step 7 (adding the mold release) but all my materials are labelled in german (i have same mold release) so i got a bit confused.
one thing i have been doing is using a flat lego base plate to make a more solid mold box.
also . . i wish my rubber was that fancy blue colour i only have a boring dark red!
current projects:-
Space Hulk and erm . . . thats about it right now!
| 04-06-2008 08:43 PM |
GRNDL
The Last Word of Hashut and Mediocrity
Posts: 1,530 - Sep 2007
Group: Immortals
Market Rep: 3
Slaves: 148
RE: [Tutorial] Resin Casing, Ishkur-styleGRNDL 04-07-2008
One tip I can add to the mix is to not pour the rubber directly onto the model, but off to the side and let the rubber "roll" over the master. This way, air won't be trapped under the poured rubber but gently pushed out when the rubber rolls over it. It won't get rid of all the trapped air but helps a lot.
Also, you can make a cheap "vacuum" bed by placing the master and freshly poured rubber into a larger box, put the whole thing into a plastic bag and then put the nose of a hand held vacuum into the bag. Use your hand or an elastic band to seal the bag around vacuum and switch it in for 10 seconds or so. This will form a negative pressure within the bag and encourage the air bubbles to rise to the surface of the rubber.
GRNDL's CD Army Blog
04-07-2008 12:46 AM |
dedwrekka
Bull Centaur Hero
Posts: 526 - May 2007
Group: Dawi Zharr
Market Rep: 2
Slaves: 29
RE: [Tutorial] Resin Casing, Ishkur-stylededwrekka 04-07-2008
I've seen the same thing done with a commercial vacuum sealer you can buy at many market places (Wal-Mart and Target in the US, no idea about other countries). Using a home vacuum sounds like the more economic option though.
A great article!
A bit on making the cast with the new two-part mould would be excellent for those doing their first cast.
This post was last modified: 04-07-2008 01:27 AM by dedwrekka.
| 04-07-2008 01:21 AM |
Narflung
Chaos Dwarf Daemonsmith
Posts: 119 - Feb 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
RE: [Tutorial] Resin Casing, Ishkur-styleNarflung 04-07-2008
Well chap, you've done it again, good work. I have always been interested in the larger scale (ie whole mini) moulds, I've been doing a much smaller scale version for details and embellishments for some time, but was unsure how to expand into larger moulds.
Cheers
| 04-07-2008 02:32 AM |
Ishkur Cinderhat
The Arch Immortal
Group: Immortals
Market Rep: 4
Slaves: 79
RE: [Tutorial] Resin Casing, Ishkur-styleIshkur Cinderhat 04-07-2008
That's a cool idea GRNDL, I was already wondering how one could simulate a vaccuum-chamber for improving the mould quality. I'll definitely try this out!
04-07-2008 07:19 AM |
torn
Lammasu
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
RE: [Tutorial] Resin Casing, Ishkur-styletorn 04-07-2008
i usually brush a thin first layer of rubber on to make sure it gets into all the gaps
current projects:-
| 04-07-2008 07:47 AM |
Sharp
Chaos Dwarf Warrior
Posts: 54 - Feb 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
RE: [Tutorial] Resin Casing, Ishkur-styleSharp 04-07-2008
Ishkur, a question for you. I happened to try my hand at casting this weekend and I ran into a small problem - Cleanup. I'm using the same 2 part silicone as you are (my bottles say 6 hours to set though) and I'm having a hard time cleaning up after. I've realized that the container I mix the actual silicone in is a write off, but I also have graduated plastic cups that I use to measure the materials in. Together these compounds are almost impossible to clean, but even separate they are a pain in the ass. The only conclusion I've come to is to wipe out the cups the best I can and label them so I only use them to measure the same material again (since I cant completely clean them.)
And in case your wondering, let the first half of your mold cure completely before taking it out to do the second half. Jello Rubber doesn't hold it's shape that well... hahaha.
| 04-07-2008 09:26 AM |
Xander
Market Rep: 7
Slaves: 1032
RE: [Tutorial] Resin Casing, Ishkur-styleXander 04-07-2008
I will most likely being sculpting my own torsos for my BBs, and then casting those. My experiment was my GH5 entry in which I sculpted the entire torso, except the nose. It came out alright, so I figure I can work on a few great torso sculpts then cast them.
04-07-2008 09:49 AM |
GRNDL
Group: Immortals
Market Rep: 3
Slaves: 148
It works well for the rubber, but I haven't tried it with the resin casting. I have my doubts that unless you have a good vacuum going throughout the process, as early as possible, then the chance of pulling air bubbles out of the resin is rather low.
If you feel you've seen improvements, let me know.
04-07-2008 10:53 AM |
