Post Reply  Post Thread
Superfella's Bull Centaurs - with photos.
Author MessageSuperfella's Bull Centaurs - with photos.
superfella
Chaos Dwarf Daemonsmith
Posts: 169 - Apr 2008
Group: Dawi Zharr
Market Rep: 5
Slaves: 7
Post: #1
Superfella's Bull Centaurs - with photos.superfella 06-18-2008
how do all.
ive decided to do this thread for two reasons, firstly, im very proud of my work on these and secondly... im very proud of my work on these..!
anyhow, first and foremost, I feel it only fair that I should say thanks to a few individuals for contributing to this project, especially as some of them will likely be unaware that they have helped me!
so.
To Starscream, my partner in crime in the work place and a real source of encouragement to finish what I start, I want to say thanks for providing me the horse bodies for the excellent cost of "show me regular photos and you can have them".
To Xander, your BFSP tutorial video was so easy to follow, it has given me confidence to try using green stuff for more than just gap filling, and I think you have done a great service to the Chaos Dwarf Community.
And thirdly, to Kera, I liked your bull centaurs so much, that they were my initial inspiration to do something similar.
Right. So, thanks aside, the following components were needed for each bull centaur:
Plastic Lord of the Rings Rohan Horse
2 Beastman Gors
Beastman Weapon Heads
Chaos Marauder Arms & Sheilds.
Chaos Warrior Head
Lots of Greenstuff or the equivolent.
below is some photos of the progress at each stage so far.
the above photos show which models are required for the main part of the model, plus which parts to remove.
basically, remove the head and legs from the horse (I also removed the tail as Im planning on sculpting a different style of tail) and scrape away the saddle. Remove the legs from the Beastmen mid-thigh, and dispose of the torso into your bits box.
Trim away any unwanted details, such as excess fur, hooks, medallions or the loin cloth, then remove the hooves from two of the legs, as these will need to be turned back to front to look right.
glue the legs into place, making sure that you position the front hooves the correct facing, otherwise the model will not look right. I assembled the initial piece without turning the hooves around and couldnt work out why it looked like it was going to tip forwards, so i refered to some pictures of horses and found that their rear legs have "knees" on the rear of the leg, whereas the front legs the knees are on the front.
once this has dried, i mixed some greenstuff and formed a rough torso shape where I wanted the body to be. I wasnt too fussed about neatness at this stage, as the detail work will get sculpted over the top.
once the torso is built up to an acceptable level that your happy with (I used a BFSP Chaos Dwarf on foot as a rough size guide), let the green stuff set for a few hours.
here you can see the height of the horse's body compared to a CD on foot. obviously once the torso is built up, the model is an extra centimetre or so taller.
once the green stuff has dried, my next step was to sculpt on some detail, in the form of the belt, skirt and shoulder trim.
to do this, i rolled a green stuff sausage and wrapped it around the models waist, flattened it and trimmed it so that i had a neat strip going around the midriff, about the thickness of the belt on a BFSP dwarf. the I did the same for the skirt, so that the scale armour can protect the models front legs. Then for the shoulder trim, I pushed a ball of greenstuff onto each "arm" position, flattened it a little to make a disc, then smoothed and rounded the edges. once I was happy with the size, i put a pair of marauder arms (one with a flail without the flail head) into place to make sure he wasnt too broad.
Now I removed the arms and allowed this part of the model to dry.
This process, ignoring the drying time for the greenstuff (I allow it to dry between stages otherwise i end up making a mess of what I have already done), took me about 3 hours for the first model, and by the time I did the 5th, It now takes about 1n hour and half per model, plus 3 to 6 hours drying time for the greenstuff.
My next post on this thread will show the head, beard, scale armour and the arms, as I have yet to sculpt the beard to the model and my camera's batteries have run out (hence the latter two pictures are off my mobile phone... not as good as i hoped for but the best I could get in the circumstances!
Please provide me with your feedback to let me know what you guys think, and whether you have any recommendations for adjusting them slightly!
thanks in advance!
06-18-2008 06:38 PM
Hashut's Blessing
The Cakily Blessed One
Posts: 5,927 - Feb 2007
Group: Retired Staff
Market Rep: 9
Slaves: 742
Chaos Dwarf Radio - Contributor Artisan's Contest - Silver Image Gallery Contributor - Bronze Bronze Army Medal - 1000 PTS Veteran Medal - Silver Word of Hashut - Contributor
Post: #2
RE: Superfella's Bull Centaurs - with photos.Hashut's Blessing 06-18-2008
That looks incredibly good. Could you not use the beastmen arms and bodies with appropriate changes to utilise more of a model at once? That way, you don't need to keep buying separate maruader arms also. Just an idea. It'll be good to see some up close pictures of the belt etc to see the detail. Do you need to remove the fur from the gor legs or add a little to the horse body to make it look good? What about simply covering the fur with some armour? (Apologies if you've said this is what you did/planned to do.)
Pledge: '09:+83 '10:+116 '11:+118 '12: N/A '13: N/A
WarplockMonkey Wrote:
06-18-2008 07:38 PM
wallacer
Hashut's cow pimp
Posts: 3,538 - Feb 2007
Market Rep: 4
Slaves: 1046
Artisan's Contest - Bronze Image Gallery Contributor - Bronze Word of Hashut - Contributor Wiki - Major Contributor Blackshard Army Medal - 10000 PTS
Post: #3
RE: Superfella's Bull Centaurs - with photos.wallacer 06-18-2008
Well, you're obviously a quick study.
I particularly like the pose of it as seen in the final picture.
It'll be good to see it with more details added.
Army pics: http://www.chaos-dwarfs.com/forum/showth...888&page=1
06-18-2008 07:44 PM
Kera foehunter
Zharr Nauggund Alpha Female
Posts: 8,568 - Sep 2007
Group: Dawi Zharr
Market Rep: 14
Slaves: 153
Post: #4
RE: Superfella's Bull Centaurs - with photos.Kera foehunter 06-18-2008
great job and thank for the step by steps too
06-18-2008 08:42 PM
Willmark
Dark Lord of Hashut
Posts: 7,912 - Aug 2007
Group: Hashut's Admin
Market Rep: 25
Slaves: 1226
Artisan's Contest - Gold Image Gallery Contributor - Gold Best Overall Member - 2007 Word of Hashut - Contributor Chaos Dwarf Radio - Contributor Best Contributor - 2008 Best Overall Member - 2008 Best Overall Member - 2012 Veteran Medal - Bronze Diamond Army Medal - 8000 PTS
Post: #5
RE: Superfella's Bull Centaurs - with photos.Willmark 06-18-2008
Looks to be great (the finished product that is) can you provide a better pic?
My Want List / My Trade List
06-18-2008 08:44 PM
wallacer
Hashut's cow pimp
Market Rep: 4
Slaves: 1046
Post: #6
I've given him some slaves, Willmark, so that should encourage him to post more pictures.
*dangles another slave enticingly in front of superfella*
06-18-2008 11:43 PM
Xander
Chaos Dwarf Ambassador
Posts: 4,757 - Feb 2007
Market Rep: 7
Slaves: 504
Post: #7
RE: Superfella's Bull Centaurs - with photos.Xander 06-19-2008
Looking stellar!  Glad I could fuel the flame!
Join us on the new forum. Come help us test it out!
https://discourse.chaos-dwarfs.com
06-19-2008 12:16 AM
superfella
Group: Dawi Zharr
Market Rep: 5
Slaves: 7
Post: #8
RE: Superfella's Bull Centaurs - with photos.superfella 06-19-2008
hehe, thanks guys!
in response to Hashut's Blessing:
I removed the fur from the Gor's legs and havent added anything to the horse's body as of yet. the armoured skirt covers the front legs from the knee up.
also, i looked at some pictures of bulls and cows, and they dont seem that hairy to me, more like thye have body hair like a horse that just lies flat on the body. Im not sure how I would do that, butif any one has any suggestions I guess I could give it a try!
Also, I used the marauder arms cos I had some spare and wanted my unit to be equipped with great weapons, and they use less adjustment than trying to do so with Gor arms. Though I am intending on doing some with two hand weapons, in which case the Gor arms will be used.
Ive got my camera on charge this morning, so hopefully I will get more pictures uploaded onto here tonight!
Thanks again for the feedback all!
06-19-2008 02:19 AM
AGPO
BOAR CENTAUR!
Posts: 3,130 - Mar 2007
Market Rep: 0
Slaves: 1271
Post: #9
RE: Superfella's Bull Centaurs - with photos.AGPO 06-19-2008
Unless you've gotthe Gors spare, would it not be simpler to use Empire horse legs? They'd give you the extra bulk without the 'furry little problem'
Check out my blogs!:
Chaos Dwarfs (6/6/09)Other shiny things (13/11/11)
I follow the Grumpy But Responsible Gamers' Charter. Join us!
Sojourn Wrote:
FYI Wilmark, the only alcohol I'm drinking is from that bucket
06-19-2008 07:28 AM
superfella
Group: Dawi Zharr
Market Rep: 5
Slaves: 7
Post: #10
that is true, however, my reasoning was as follows:
Kera's BCs used Gor legs which was my initial inspiration for these, so I wanted to emulate those, and I had 10 Gors spare from my beasmen army.... surely a sign from Hashut himself that this project was meant to be!
also, I wanted cloven hooves, which horses dont have, so I would have to cut the horse hooves to give the desired effect.
Finally, when i was talking with starscream bout how to do some BC when I made my first few CD as per Xander's video tutorial, we decided that the plastic Empire horse was too large for this project and the BFSP pony was too small (which i discovered AFTER trimming all the details off... grumble!).
so that left the LOTR horse bodies as they are sized between the two.
Im pleased with results so far.
I just wish I had a holiday in for this afternoon so I could go home and do some more work with them!
BTW, when they are built, should I post the pictures of the paint jobs in this thread, or should I post a new thread?
06-19-2008 07:50 AM
minty
Lammasu
Posts: 876 - Jun 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #11
RE: Superfella's Bull Centaurs - with photos.minty 06-19-2008
Wow, they be awesome, almost making me want to get back to my bull centaurs.
Maybe bulk outt the upper end of the bull centaur bull part, it's just if you do look at bulls, there much broader at the front than back
still, awesome work thereHappy
06-19-2008 10:09 AM
starscream
Bull Centaur Hero
Posts: 538 - May 2008
Group: Dawi Zharr
Market Rep: 9
Slaves: 23
Post: #12
RE: Superfella's Bull Centaurs - with photos.starscream 06-19-2008
there i was, mindlessly chatting away...
Superfella: "so I'm gonna try Keras bc thing, i have some spare skeletal steeds i can flesh out with green stuff"
Me: "nah that'll be difficult".
Superfella: "What do you reckon then".
Me: "Rohan horses would be about right".
Superfella: "yeah that could work, I could get some of those".
Me: (still not awake) " oh I have some ".
Superfella: "yoink!"
and that dear readers is how my never-really-got-off-the-ground Rohan army lost their rides. Take this as a warning, never let someones enthusiasm take advantage of your hungover state or you'll lose your minis.....
... I got my own back when he let it slip yesterday he has 3 unused Chimera (and me having just bought some steel legion?  Suits you sir!
My bighats army blog
http://www.chaos-dwarfs.com/forum/showth...758&page=1
06-19-2008 10:30 AM
superfella
Group: Dawi Zharr
Market Rep: 5
Slaves: 7
Post: #13
well I have now finished the first model bar the axe head, but the macro function on my camera has decided not to play nice, so Im afraid the picture quality is terrible, even worse than my mobile phone's camera.
I will "obtain" my other half's camera over the weekend and post better shots, as you cant make out all the details on the armour / beard from the ones I got.
06-19-2008 06:20 PM
Hashut's Blessing
Market Rep: 9
Slaves: 742
Post: #14
RE: Superfella's Bull Centaurs - with photos.Hashut's Blessing 06-19-2008
I assume you have filed the legs to make it look like muscles. As for the fur like a bull's/horse's you needn;t do anything in that case, surely? (Also, I know bulls aren't furry [unless you include yaks and aurochs Tongue ], but you may decide to be different is all.) It makes sense to use the marauders in that case Wink
starscream, hindsight is always 20-20, unfortunately. I'm just trying to think of what ya could do with the riders... I may buy them from you and I guess you could always heat their legs SLIGHTLY and adjust the position, remove the saddle and stand them up...
06-19-2008 07:12 PM
starscream
Bull Centaur Hero
Group: Dawi Zharr
Market Rep: 9
Slaves: 23
Post: #15
RE: Superfella's Bull Centaurs - with photos.starscream 06-20-2008
if you want them Hashuts blessing you are welcome to them.
06-20-2008 05:38 AM
Kera foehunter
Group: Dawi Zharr
Market Rep: 14
Slaves: 153
Post: #16
RE: Superfella's Bull Centaurs - with photos.Kera foehunter 06-20-2008
well thanks guys . iam glade my bc helped
06-20-2008 06:14 AM
Hashut's Blessing
Market Rep: 9
Slaves: 742
Post: #17
RE: Superfella's Bull Centaurs - with photos.Hashut's Blessing 06-20-2008
PM sent...
06-20-2008 03:22 PM
superfella
Group: Dawi Zharr
Market Rep: 5
Slaves: 7
Post: #18
RE: Superfella's Bull Centaurs - with photos.superfella 06-22-2008
ok, well, i have now finished two of my bull centaurs, a standard BC and the unit musician.
photos below!
btw, i have added a weapon head to the standard BC now, will get a pic asap.
let me know what you guys think!
06-22-2008 05:27 PM
minty
Lammasu
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #19
RE: Superfella's Bull Centaurs - with photos.minty 06-22-2008
*extra drool* Ok, I need more GS, the BC pull is too strong to resist
very nice models there, cannot think of much to sayHappy
06-22-2008 05:55 PM
starscream
Bull Centaur Hero
Group: Dawi Zharr
Market Rep: 9
Slaves: 23
Post: #20
RE: Superfella's Bull Centaurs - with photos.starscream 06-22-2008
nice one matey. Keep going.
06-22-2008 07:10 PM
Possibly Related Threads...
  Bull Centaurs and Hobgoblins Bitterman 2 960 07-18-2020 10:48 AM
Last Post: Admiral
  Bull Centaurs - Making a full unit from alternate models? RiTides 5 5,491 12-15-2014 05:42 PM
Last Post: RiTides
  FW Bull Centaurs Great Weapons options Doombeard 3 2,309 10-12-2014 03:51 PM
Last Post: Doombeard
  Questions about Greebo's Bull Centaurs Danzig 3 2,924 09-03-2013 07:29 PM
Last Post: Danzig
  Ideas for Bull centaurs? Kamphre 9 3,970 03-30-2013 07:28 PM
Last Post: Goltor Lintrepide
View a Printable Version
Send this Thread to a Friend
Forum Jump:
