Post Reply  Post Thread
Bolt thrower tutorial (as seen in HoH)
Author MessageBolt thrower tutorial (as seen in HoH)
Bassman
Greater Daemon of Hashut
Posts: 1,749 - Sep 2008
Group: Immortals
Market Rep: 0
Slaves: 640
Golden Hat - Silver Golden Hat - Bronze Word of Hashut - Contributor Golden Hat  - Gold x2
Post: #1
Exclamation  Bolt thrower tutorial (as seen in HoH)Bassman 09-13-2008
Hello,
I'd like to show you my bolt thrower tutorial.
Every Chaos Dwarf have to face the big problem of bolt throwers. If you are a billionaire you have no problems: just get 6-8 of them on ebay for 20-25 € each (around 30 $ each).
An alternative is the classic dwrf bolt thrower (difficult to find and expensive) or the cheap solution of the goblin bolt thrower. Hobgoblin
I do not really like goblin one, so I had a "big" problem to solve.
I looked around in my bit box and did not find anything.....
hanging around I get my old sprues and..... Evil idea
Why do not built it from scratch? Happy
Here is the result:
a comparison shot with my crew hobgoblins:
Hey! But it is a tutorial! How I made them?
Alan the evil Wrote:
bassman spoke... and I do agree!!
Are you interested in the Last Supper by Leonardo da Vinci? Check here: https://milanoarte.net/en/portfolio/the-...nci-milan/
Fancy an unique sculpted miniature or a good paint job?
This is my professional service: https://www.facebook.com/BluebeardsForge
This post was last modified: 04-21-2009 02:17 AM by Bassman.
09-13-2008 09:24 AM
Bassman
Group: Immortals
Market Rep: 0
Slaves: 640
Post: #2
RE: Bolt thrower tutorialBassman 09-13-2008
The power of the Bluebeards' clan lies in the masssive forges hundreds of metres below Zharr Naggrund. In those places, never touched by sun light, Chaos Dwarfs carry dark rituals for the production of evil machineries of war. But the power of the clan comes also from the endless factories just outside their sector of Zharr Naggrund. There, thousands of slaves, men and other breeds of lesser races, work under the scourge of hobgoblins' slavers to produce simpler but not less effective machines of war...
Here is the "making of" Takes Hat off
Step 1
In each 6th ed starter set there are orc sprues, in each one there are two curved pieces at the center, they'll form the support for the spear. Don't they are the exact copy? Who cares? These are supposed to be hobgoblin bolt throwers!!
The white plastic is plasticard, of course.
Step 2
Shape the bow using the two pieces of plasticard, carefully bend the largest piece od plasticard and then fix the smaller one, in this way the larger one preserves its bended shape. Once the glue is sealed, you can start to shape the bow using an hobby knife.
Step 3
Once you have shaped the bow with an hobby knife, you can use green stuff to make the four ring of metal that should keep the two part of the bow together.
Glue the bow and the bar together. The bar could be decorated as you prefer, I added an hook to keep in tension the chord using one of the horns of a dwarf helmet Wink (see pic 2 in first post) and a square piece of plastic to emulate the "thing" that will push the spear.
In the meanwhile I cut pieces of sprues to make the pieces of the frame of the bolt throwers and started to glue the support on bases.
The spears are from a boar boy reagiment but can be taken wherever you prefer.
Step 4
The bolt throwers are finally taking shape. Glue the vertical part of the frame and make two supports for them, they are taken from the same sprues. Do not care too much about precision, they are hobgoblins stuff! Happy Just be careful to inclination of the structure, and be careful they are glued proppa, because they could be very fragile.
Step 5
Job almost done! Place bows on position on the frame BEFORE placing the chords!
For the chords I used copper wires inside an old cable I had lying for ages. If you do not have bended enough the bow you can use tension of the wire to keep them in place, be careful, they are fragile!
Glue the spear in position and you're ready to shot your enemies.
Step 6
Having the structure you can apply decorations, if you want, like trophies, spears, weapons, basing, whatever you like.
I suggest before assembling to make scratches and cuts of the wooden frame, they'll look more hobgoblins' Wink
This post was last modified: 01-04-2009 11:56 AM by Bassman.
09-13-2008 10:01 AM
Geckilian
Chaos Dwarf Hero
Posts: 233 - May 2008
Group: Dawi Zharr
Market Rep: 12
Slaves: 0
Army Showcase
Post: #3
RE: Bolt thrower tutorialGeckilian 09-13-2008
Gotta say, very, very nice work there! Well done on a great conversion, which is highly economical too.
http://gecksi.mybrute.com
Will Blood Bowl for slaves.
09-13-2008 05:25 PM
Canix
Spirit of Hashut
Posts: 1,173 - May 2007
Group: Immortals
Market Rep: 8
Slaves: 10
Post: #4
RE: Bolt thrower tutorialCanix 09-13-2008
Great cheap conversion guide,nice workRespect to the Hat!
Realists are hampered by there inability to comprehend the true nature of reality
The Pledge 2010:
Bought:11 Painted:12
09-13-2008 07:53 PM
Kera foehunter
Zharr Nauggund Alpha Female
Posts: 8,568 - Sep 2007
Group: Dawi Zharr
Market Rep: 14
Slaves: 153
Post: #5
RE: Bolt thrower tutorialKera foehunter 09-14-2008
thats great Bassman! thanks very much for that !!!it so simple!!
09-14-2008 05:09 AM
Bassman
Group: Immortals
Market Rep: 0
Slaves: 640
Post: #6
RE: Bolt thrower tutorialBassman 09-15-2008
thank you guys. My idea was to keep it simple for mass production, everybody knows we need a lot of bolt throwers.
With this tutorial you can build playable basic bolt throwers . I hope to show you soon how to embellish with more details.
You can already see some of the thropies Big Grin
And nobody can say they are not GW models, 90 % is GW stuff Happy
09-15-2008 06:05 AM
Xander
Chaos Dwarf Ambassador
Posts: 4,757 - Feb 2007
Group: Hashut's Admin
Market Rep: 7
Slaves: 504
Post: #7
RE: Bolt thrower tutorialXander 10-09-2008
Really well done!  Excellent use of the sprue leftovers!
Join us on the new forum. Come help us test it out!
https://discourse.chaos-dwarfs.com
10-09-2008 09:51 AM
centauro enano
Chaos Dwarf Hero
Posts: 269 - Oct 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 121
Post: #8
RE: Bolt thrower tutorialcentauro enano 01-03-2009
Good tutorial, I am building some.
Do you have some painting? I would like to see it finished, a greeting Cheers!.
01-03-2009 01:14 PM
Willmark
Dark Lord of Hashut
Posts: 7,912 - Aug 2007
Market Rep: 25
Slaves: 1226
Artisan's Contest - Gold Image Gallery Contributor - Gold Best Overall Member - 2007 Word of Hashut - Contributor Chaos Dwarf Radio - Contributor Best Contributor - 2008 Best Overall Member - 2008 Best Overall Member - 2012 Veteran Medal - Bronze Diamond Army Medal - 8000 PTS
Post: #9
RE: Bolt thrower tutorialWillmark 01-03-2009
Man... how the hell did I miss these? This tutorial might be useful for something, I wonder what... Happy
My Want List / My Trade List
01-03-2009 05:01 PM
Viskar Zhragoth
Chaos Dwarf Hero
Posts: 234 - May 2008
Group: Dawi Zharr
Market Rep: 1
Slaves: 0
Post: #10
RE: Bolt thrower tutorialViskar Zhragoth 01-03-2009
Agreed Willmark, Excellent Work Bassman!
Have to have a go at this, after my other project is done.....mhuwhahaha!
"You have been chosen to be embraced by Hashut."
2009 Resolution - Paint 1000 models this year!
Painted so far : 28    01/07/2009
This post was last modified: 01-03-2009 05:19 PM by Willmark.
01-03-2009 05:16 PM
Hammerhand
Bull Centaur
Posts: 487 - Aug 2007
Group: Dawi Zharr
Market Rep: 1
Slaves: 14
Post: #11
RE: Bolt thrower tutorialHammerhand 01-03-2009
wow man, great job - I haven't seen those gobbos in years, they're the ones from the old WHFB boxed set right? [the one with elves and gobbos] with the really sharp spears that drew my blood more than once!  I really like the solid look of the bolt throwers that sets them aside from normal goblin ones. Nice.
It's been a long time baby, but I guess the mark of Hashut just burns too deep.......
01-03-2009 08:41 PM
al-hashut
Chaos Dwarf Sorcerer
Posts: 330 - Jul 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 8
Golden Hat - Gold
Post: #12
RE: Bolt thrower tutorialal-hashut 01-03-2009
Great stuff bassman. Nice that you've kept the essence of the original at a fraction of the price. The crew look good as well, but i'm really impressed by the lantern carrying bighat lurking in the background. Any chance of a close up?
01-03-2009 11:52 PM
Bassman
Group: Immortals
Market Rep: 0
Slaves: 640
Post: #13
RE: Bolt thrower tutorialBassman 01-05-2009
Hello guys,
thank you for kind words. My will was not to create modelling masterpieces but build fast and cheap bolt throwers that look not-so-bad.
I'm quite pleased by the result Respect to the Hat!.
centauro enano and Viskar : I wish to see your creations, I'm sure they'll be much better than mine ahahhaha Happy
Willmark : I'll try to do my best Cheers!
Hammerhand: I think so, they should be from 4th edition starter set. I got them from a super cheap bargain on ebay. I've over 30 spear gobbos and over 30 bowgobbos. They are my hobgoblins Hobgoblin
al-hashut: thank you. You should already know him from my army blog Unsure
http://www.chaos-dwarfs.com/forum/showth...p?tid=3392
01-05-2009 02:04 PM
centauro enano
Chaos Dwarf Hero
Group: Dawi Zharr
Market Rep: 0
Slaves: 121
Post: #14
RE: Bolt thrower tutorialcentauro enano 01-05-2009
Hey Bassman, now I have very little built Big Grin.
I will add slaves when you paint the bolt thrower Takes Hat offTakes Hat off
01-05-2009 04:23 PM
Bassman
Group: Immortals
Market Rep: 0
Slaves: 640
Post: #15
Damn it! I've just finished my blunderbusses and I cannot have a rest... ahhahaha Shock
slaveeeeees, my preciousssss Respect to the Hat!
01-05-2009 04:40 PM
CheTralfara
Posts: 396 - Nov 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 21
Post: #16
RE: Bolt thrower tutorialCheTralfara 01-05-2009
Bassman, please do not take offense to this.. but would you consider making the skirt of your hobgoblin archers's cloak a little longer... right now it kinda looks a little too...... girly?
once again, please don't take this the wrong way. I mean no offense, I just think it would look better as a cloak, while now it looks kinda like a skirt... and makes him also look a little strangely atheletic? (not sure why). You could extended the skirt part just like you did with the former spearman goblin. Those goblin models make great starts for hobbos by the way. Glad you made them human size instead of just using them as is Happy Happy Happy
MY CHAOS DWARFS!
01-05-2009 08:52 PM
Bassman
Group: Immortals
Market Rep: 0
Slaves: 640
Post: #17
RE: Bolt thrower tutorialBassman 01-06-2009
No offense at all! I'm happy to have suggestions. Yes, they look like skirts Tongue Unfortunately they are already painted but in next projects I'll made them longer to cover the entire legs. This way i'll avoid sculpting the new legs!
01-06-2009 06:38 AM
Bassman
Group: Immortals
Market Rep: 0
Slaves: 640
Post: #18
RE: Bolt thrower tutorialBassman 04-21-2009
To celebrate the release of new Hands of Hashut with my article from this tutorial, new pics of the first painted bolt thrower! Respect to the Hat!
Enjoy Takes Hat off
04-21-2009 02:13 AM
Bassman
Group: Immortals
Market Rep: 0
Slaves: 640
Post: #19
and the brave Shock crew hobgobbos:
naked:
(badly) painted:
Cheers!
04-21-2009 02:16 AM
centauro enano
Chaos Dwarf Hero
Group: Dawi Zharr
Market Rep: 0
Slaves: 121
Post: #20
RE: Bolt thrower tutorialcentauro enano 04-21-2009
Good job, I send you the slave as promised Cheers!Cheers!
color as that used for wood ?, a greeting.
This post was last modified: 04-21-2009 12:37 PM by centauro enano.
04-21-2009 12:34 PM
Possibly Related Threads...
  Bolt thrower bases Will Liam 14 3,044 04-08-2017 11:51 AM
Last Post: Nicodemus
Toungue Hobgoblin Steam-powered Bolt Thrower mk II Lord Aldades 2 3,695 10-14-2011 06:27 PM
Last Post: Abecedar
  Yet another Bolt Thrower... Blind Berzerker 18 9,256 11-16-2010 10:49 AM
Last Post: Tribun
  Hobgoblin Bolt Thrower from BFSP pieces. Tarrakk Blackhand 7 8,427 03-04-2010 01:16 PM
Last Post: Tarrakk Blackhand
  Bolt Thrower with Power! Snotling 47 34,241 02-28-2009 02:15 PM
View a Printable Version
Send this Thread to a Friend
Forum Jump:
