Post Reply  Post Thread
Onii's very first chaos dwarfs
Author MessageOnii's very first chaos dwarfs
Onii One Orc
Hobgoblin
Posts: 39 - Dec 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #1
Onii's very first chaos dwarfsOnii One Orc 01-27-2009
I picked up some BFSP Thunderers yesterday and attempted to make them into chaos dwarf blunderbusses.  The terrifying results are the images you see below.  Happy
What I've found needs the most work is the beards, which are surprisingly difficult to do.  I haven't yet added scale armour, and the one fellow still needs a helm/mask, but otherwise I think they'll look decent once painted up.  Practice is expected to make better results.
I'm not sure how happy I am with the mask that has the vertical bars, but I do like the way the other came out.  I used a toothpick for that, and had some idea of making the holes look like spider-eyes, just by their placement.
2017 Image Salvage
Found on the internet:
"Why can't he PM the mods?  Is his PM button broken?"
This post was last modified: 08-08-2017 06:17 AM by Admiral.
01-27-2009 04:27 PM
Swissdictator
Hashut's Code Monkey
Posts: 1,962 - Mar 2008
Group: Hashut's Admin
Market Rep: 1
Slaves: 1348
Best General - 2008 Best General - 2009 Gold Army Medal - 4000 PTS Word of Hashut - Contributor Chaos Dwarf Radio - Contributor Best General - 2010
Post: #2
RE: Onii's very first chaos dwarfsSwissdictator 01-27-2009
I agree, the one you used the toothpick for is nice. Good work!
Though I like the beard on the other just a tiny bit more.
Nice start! You're doing much better then I did when I started.
FORGET AoS. Whoever designed it isn't fit to pour [water] out of a boot with instructions written under the heel.
This post was last modified: 01-27-2009 07:01 PM by Swissdictator.
01-27-2009 07:00 PM
Ogranoth blackhammer
Hobgoblin
Posts: 35 - Jan 2009
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #3
RE: Onii's very first chaos dwarfsOgranoth blackhammer 01-27-2009
how did you do the mask?
W/D/L FANTASY 09!
0 1 0
CD forces = 1 solitary standard bearer....so far.
01-27-2009 07:05 PM
Onii One Orc
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #4
RE: Onii's very first chaos dwarfsOnii One Orc 01-28-2009
The mask is simply a thin sheet of green stuff slapped onto his face and shaped into a smooth section.  I took my sculpting tool and did a smooth vertical cut on each side to get the edges straight, after I'd pressed the front smooth.  The way I see it, it's like a non-removable visor that's actually part of the helmet.  For the one with the eyeholes, I took a toothpick and wet the end in water, and then simply poked holes where I thought they should go.
The vertical mask is done the same way, except the slashes were made with my sculpting tool.  That one still needs practice...
If I remember right, on one of the dwarves I took off his face and eyebrows with my x-acto before applying the mask, on the other I didn't.  I'm not sure yet that it matters that much, though.
Also, it's hard to tell in the pics, but the green stuff mask doesn't cover his entire helmet, it stops just a bit below where the crest of the helmet would be.
Does that make sense?  Let me know if you have any more questions, and I'll try to be helpful.  I'll also continue to post updates here, as I finish/continue each dwarf.
01-28-2009 04:00 AM
Kera foehunter
Zharr Nauggund Alpha Female
Posts: 8,568 - Sep 2007
Group: Dawi Zharr
Market Rep: 14
Slaves: 153
Post: #5
RE: Onii's very first chaos dwarfsKera foehunter 01-28-2009
Dude!!! i really like the masks!! thanks for you imfo  on them to
01-28-2009 06:35 AM
Xander
Chaos Dwarf Ambassador
Posts: 4,728 - Feb 2007
Market Rep: 7
Slaves: 445
Post: #6
RE: Onii's very first chaos dwarfsXander 01-28-2009
Excellent!  I like the masks! Happy
Follow CDO on Twitter: Twitter
01-28-2009 12:14 PM
Bassman
Greater Daemon of Hashut
Posts: 1,748 - Sep 2008
Group: Immortals
Market Rep: 0
Slaves: 640
Golden Hat - Silver Golden Hat - Bronze Word of Hashut - Contributor Golden Hat  - Gold x2
Post: #7
RE: Onii's very first chaos dwarfsBassman 01-28-2009
Nice style! If you do not mind I'd like to give you some suggestions:
1) beards: I ue a techinque very slow but really effective, just make a sausage of GS per each strand of beard. Apply one strand per time and start to sculpt the beard. Be careful, start from the center, then the sides. This will help you to keep the "round" shape of the strand, becasue pressure from the sides will help to not flatten the strand.
Use quite hard GS (more blue).
If you check my Bluebeards army blog you could find some nice results Happy
2) masks: spider mask is really cool! Try to get a metal point tool, it is better than wood.
Vertical one: why do not try to cut the vertical bar from hardened GS? They'll be better. Many people do underestimates the potentials of sculpting harden GS! Respect to the Hat!
Keep on with your good work!
Bassman
Alan the evil Wrote:
bassman spoke... and I do agree!!
Are you interested in the Last Supper by Leonardo da Vinci? Check here: http://milanoarte.net/en/tour/the-last-s...ly-for-you
Bored of slashing your slaves? Take a vacation in Milan:
http://www.milantour.net
01-28-2009 12:23 PM
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #8
RE: Onii's very first chaos dwarfsOgranoth blackhammer 01-28-2009
how thin is thin? like a quarter of a CM?
W/D/L FANTASY 09!
0 1 0
This post was last modified: 01-28-2009 05:40 PM by Ogranoth blackhammer.
01-28-2009 05:40 PM
Onii One Orc
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #9
Ogranoth:  Yeah, that sounds about right.  It's enough to cover the face and still sculpt eyeholes and such without grazing plastic underneath.
(I'm guessing you're asking about "thin" in regards to the masks.)
01-28-2009 09:27 PM
Hobgoblin
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #10
yes i was. thanks. just tried it. turned out semi ok (beginner to GS)
i'll post pics in my blog in a few
W/D/L FANTASY 09!
0 1 0
01-28-2009 10:23 PM
Sojourn
Bull Centaur Lord
Posts: 614 - Feb 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #11
RE: Onii's very first chaos dwarfsSojourn 01-29-2009
your lines are very clean.... they look great.
maybe a little more detail? if you do then painting them will be that much better with more crevices for low lights, etc Happy
self-assigned gold stars:
x 7
WarplockMonkey Wrote:
On special orders by Sojourn, Crayola created a Sojourn-coloured crayon. No matter what you draw with it, the result will always be a picture of Sojourn in her CDO t-shirt, looking smug.
01-29-2009 10:37 AM
Zanko
Prime Frurndar of Hashut
Posts: 3,187 - Dec 2008
Group: Immortals
Market Rep: 11
Slaves: 1302
Blackshard Army Medal - 10000 PTS Image Gallery Contributor - Blackshard Word of Hashut - Contributor Veteran Medal - Gold Diplomat Medal - Bronze Major Prize Sponsor Photobucket Migration Exceptional Help Golden Hat - Gold
Post: #12
RE: Onii's very first chaos dwarfsZanko 01-30-2009
Keep it up!
I want to see them painted! Happy
              Hashut!
         "Frurndar are still existing!"
               The Lizard King
01-30-2009 03:37 PM
Merchant
Bull Centaur Hero
Posts: 522 - Sep 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 5
Post: #13
RE: Onii's very first chaos dwarfsMerchant 02-09-2009
I agree with them all, keep them coming and let us see them painted Happy
Blasting Zombies since 1987!
When the traitor's hand strikes, it strikes with the strength of a legion.
02-09-2009 07:01 AM
Ubertechie
Bull Centaur Hero
Posts: 533 - May 2008
Group: Dawi Zharr
Market Rep: 5
Slaves: 3
Post: #14
RE: Onii's very first chaos dwarfsUbertechie 02-09-2009
They look great - even more so for a first attempt
_________________
Bryan "Ubertechie" Carmichael
The Unseen Lerker Team
_________________
Unseen Lerker magazine - more awesome than a hedgehog in a sock.
02-09-2009 09:32 AM
Revlid
Bull Centaur
Posts: 405 - Feb 2007
Group: Dawi Zharr
Market Rep: 0
Slaves: 191
Artisan's Contest - Gold Golden Hat - Gold Veteran Medal - Bronze
Post: #15
RE: Onii's very first chaos dwarfsRevlid 02-19-2009
A good job on the masks! For the vertical bars one, I'd suggest you make the bars smaller next time - cut them off at about half-way from their current top.
As for the beards, I'd recommend you read this.
Madness? THIS IS... Well, maybe it isn't Sparta, but it's still pretty awesome.
Would you kindly comment on my Warhammer Armies: Chaos Dwarfs?
02-19-2009 01:52 PM
Joshmohr
Bull Centaur
Posts: 474 - Dec 2008
Group: Dawi Zharr
Market Rep: 1
Slaves: 65
Post: #16
RE: Onii's very first chaos dwarfsJoshmohr 02-19-2009
With CD's, you either pick it up quick, or need to work on it. I'd say that everyone here picks it up quick!
I like the slash-marks mask, but the beard should be a bit straighter with the dreadlocks.
__________________________________________________
What signature?
02-19-2009 11:43 PM
tetnis
Chaos Dwarf Warrior
Posts: 76 - Jun 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 1
Post: #17
RE: Onii's very first chaos dwarfstetnis 02-20-2009
My beards have been flattening out like that too.  Does anyone know how to keep them rounder, like on the original bighat models?
02-20-2009 12:29 AM
Captain Crayon
Chaos Dwarf Daemonsmith
Posts: 130 - Mar 2008
Group: Dawi Zharr
Market Rep: 7
Slaves: 6
Post: #18
RE: Onii's very first chaos dwarfsCaptain Crayon 02-20-2009
I also want to see the painted results Happy
as for keeping them rounder, how about rolling the greenstuff, slapping it on then letting it set then maybe filing/cutting the ridges into it
02-20-2009 03:15 AM
two_heads_talking
Lammasu
Posts: 891 - Aug 2008
Group: Dawi Zharr
Market Rep: 2
Slaves: 0
Post: #19
RE: Onii's very first chaos dwarfstwo_heads_talking 02-20-2009
Perhaps, before you get those vertical lines in the mask, you form the mask the way you want.. LIke the visor on Templars  helm..  after you've got the complete mask done, then come back and cut in the vert vents.  I think what happened is that you put them in before the mask was complete and before it dried some and it pushed the mask flat..
I could be wrong, but I get impatient too.
02-20-2009 08:49 AM
View a Printable Version
Send this Thread to a Friend
Forum Jump:
