Post Reply  Post Thread
Tutorial: Making rivets/bolts.
Author MessageTutorial: Making rivets/bolts.
m3lvin
Chaos Dwarf Hero
Posts: 232 - Aug 2009
Group: Dawi Zharr
Market Rep: 0
Slaves: 306
Word of Hashut - Contributor Golden Hat  - Gold x2
Post: #1
Tutorial: Making rivets/bolts.m3lvin 11-06-2009
Hello!
I got asked on my blog how I made my Rivets/bolts on my models,
so I decided to make a small tutorial.
I copied the text here so more of you people got a chance to see it.
Perhaps it feels silly to make a tutorial on just making rivets/dots. It feels like it's such a small thing, but it's not.
When sculpting your own armour to your CDs the rivets/dots are a really important part,
and making them look good really boosts the overall look of the model.
It's worth a try.
When I make my Rivets/bolts on my miniatures, I use two different technicues.
You could just roll tiny balls and dab them on, but the risk is that they'll be in different sizes, oval, etc.
Therefore I started using a special übertool... a normal pen!
This is the ultimate tool for making small Rivets/bolts. you can even chose the diameter,
depending on which pen you use, 0,5mm or 0,7mm. just remember to remove the graphite stick.
an alternative to a pen, Is the metal pipes the are used in certain precision humbrol glues.
not certain of the diameter there though, but it's smaller than 0,7mm.
Anyhow, as said, there are two different thecniques I use:
Type 1 is the most simpe, which anyone can use without any certain sculpting experience.
When using this technique, the rivets/bolts will be the same height level as the plate, it won't piont out.
Sometimes it can look a little bit lazy/unprofessional doing this, but not if you dont overuse it.
Type2 requires a lot more patience/experience, but will look more professional.
These rivets/bolts will rise over the plate it's applied on.
Step by Step:
Type-1:
1. These rivets/bolts always has to be applied on an uncured part of greenstuff (a newly sculted shoulderplate for example),
which is in this stage represented by a blob of greenstuff.
2. With a steady hand, simply push the pen into the greenstuff.
you can decide how deep the recesses will be by pushing hard or soft.
just remember to dip the tip of the pen in water before pushing it into the greenstuff.
Also, make sure there's no graphite stick in, otherwise you'll just get a black dot.
Type-2:
1. Apply a tiny ball of greenstuff where you want the rivet/bolt to be placed. It's very important that the ball is applied onto a part of greenstuff which is CURED, otherwise it wont work.
2. Push the ball to the thickness you want the rivet/bolt to be in the end.
3. Push a hole with the pen (use water). make sure that the pen goes the whole way thru down to the hard, cured layer.
4. Start removing the leftover greenstuff on the sides, I use a small hobbyknife or scalpel.
Cut a line from the inner circle all the way out.
If you pushed the pen the whole way through, you could now pretty easily remove the left over green stuff with the tip of the blade.
5. Finished! circural and perfect!
Examples of rivets/bolts:
model: Hobgoblin Hero
Hope this tutorial was helpfull!
Takes Hat off
/melv
Spare time? Evaluate my Skulltank rules!
| other armies (more to come) |:
11-06-2009 09:04 PM
Thorne
Greater Daemon of Hashut
Posts: 1,054 - May 2009
Group: Immortals
Market Rep: 1
Slaves: 300
Post: #2
RE: Tutorial: Making rivets/bolts.Thorne 11-06-2009
Thanks I cant say I ever thougth of that way of making rivets it will be great for my kollosus model !
2017 Image Salvage
1, Come see things the space dwarf way.
2, My bases and scenic store
3, My spectre scenic products blog.
This post was last modified: 08-08-2017 08:57 AM by Admiral.
11-06-2009 09:07 PM
Da Crusha
K'daai Destroyer
Posts: 2,400 - Dec 2008
Group: Immortals
Market Rep: 10
Slaves: 433
Best General - 2010
Post: #3
RE: Tutorial: Making rivets/bolts.Da Crusha 11-07-2009
nice tutorial, I actually always wondered how to sculpt rivets and what a pain it was going to be to keep them uniform. I think this should get stickied right along with your bolt thrower tutorial
Da Crusha's non-big hat army blog
Seaside Slaughter 2
This post was last modified: 11-07-2009 05:51 AM by Da Crusha.
11-07-2009 05:51 AM
Baggronor
The Forgemaster
Posts: 2,640 - Feb 2008
Group: Immortals
Market Rep: 9
Slaves: 617
Army Showcase Best Contributor - 2009 Word of Hashut - Contributor Artisan's Contest - Gold Best Contributor - 2010 Best Contributor - 2012 Best General - 2013 Major Prize Sponsor Hellsmith - Gold
Post: #4
RE: Tutorial: Making rivets/bolts.Baggronor 11-07-2009
Dude, you rock. My days of insanely scrutinising little blobs of GS are now over. Have some slaves Cheers!
http://www.titanwargames.com
11-07-2009 10:47 AM
Khunag
Chaos Dwarf Daemonsmith
Posts: 193 - May 2009
Group: Dawi Zharr
Market Rep: 1
Slaves: 0
Post: #5
RE: Tutorial: Making rivets/bolts.Khunag 11-07-2009
Other very easy method is to just put tiny little blobs of pva glue with a toothpick. They look a bit different, more dome-shaped, but it's very fast and easy.
http://trollsforge.com/
Stormcrow Wrote:
When a CD goes to the bar after a long day of whipping, its hat size that is going to determine who he spends his night with.
11-07-2009 11:17 AM
m3lvin
Chaos Dwarf Hero
Group: Dawi Zharr
Market Rep: 0
Slaves: 306
Post: #6
RE: Tutorial: Making rivets/bolts.m3lvin 11-07-2009
Khunag: that's genious!! have to try that sometime Cheers!
11-07-2009 03:12 PM
Khunag
Group: Dawi Zharr
Market Rep: 1
Slaves: 0
Post: #7
Yeah, it works pretty good, I didn't invent it though, read about it on some forum i think Happy I've been also experimenting with thick paint, you can do the same thing with that, and if your careful you can even put some embossed letters on swords etc.
11-07-2009 06:05 PM
black hammer
Posts: 122 - Jul 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 27
Post: #8
RE: Tutorial: Making rivets/bolts.black hammer 11-08-2009
Nice!  I've always had trouble sculpting consistantly sized rivets.  This solves the problem!
11-08-2009 12:49 AM
Possibly Related Threads...
  Video Tutorial: Mold Making and Resin Casting Xander 21 19,011 08-17-2010 09:54 PM
Last Post: Peanutplant
  Face making tutorial wallacer 9 2,964 10-19-2008 01:15 PM
Last Post: furrie
View a Printable Version
Send this Thread to a Friend
Forum Jump:
